September 30, 2026, 08:19:17 PM
Author Topic: Screeching/high pitch sound while accelerating  (Read 17767 times)
Silver Bullet
Silver Bullet pfffft.
« on: January 08, 2011, 01:20:29 PM »
Hey guys, this morning while accelerating, my car started making a high pitch screeching sound and it stops when I shift into the next gear but it starts again until I shift. It will pretty much start at 2,000 rpm and up. It just started doing this today and does not sound normal. Could anyone tell me what it could possibly be? It's a 2006 v6 6 speed with 87k miles.
2006 AV6 6MT
« Reply #1 on: January 08, 2011, 03:21:40 PM »
Sounds like a serpentine belt slippage. Check your belts for wear and replace if necessary.
I had the same issue on my other car, changed the belt, still did it. Come to find out it was the tensioner pulley. GL
Silver Bullet
« Reply #2 on: January 08, 2011, 03:29:59 PM »
I did some additional research on other cars and as well and you may be right. I just bought this car. The last owner may not have changed it. Thanks for the help slipkord. Btw, how much did it cost to have your belt replaced?
2006 AV6 6MT
« Reply #3 on: January 08, 2011, 03:33:31 PM »
I don't remember, been sometime since I replaced it. $20 most likely
« Reply #4 on: January 08, 2011, 08:38:03 PM »
Sounds like a belt to me.  Shouldn't be more than around $20 or so.  Change it yourself and save some money.
« Reply #5 on: January 08, 2011, 10:07:25 PM »
Locally I've found the belt to actually be cheaper at the dealer as fucked up as that sounds.
« Reply #6 on: January 08, 2011, 11:04:44 PM »
Unless you have to find a custom sized belt like I do.
Silver Bullet
« Reply #7 on: January 08, 2011, 11:54:00 PM »
Just out of curiosity guys, how much longer can I go until it's mandatory? I won't have any time to do it until Tuesday and would you guys recommend aftermarket vs oem?
2006 AV6 6MT
« Reply #8 on: January 09, 2011, 01:18:35 AM »
Oem or a quality brand gates for example
« Reply #9 on: January 09, 2011, 02:17:36 AM »
This.
