June 21, 2026, 04:46:08 PM
Engine RATTLE idle? mounts?
Topic: Engine RATTLE idle? mounts? (Read 23313 times)
phatmastaflip
September 23, 2010, 07:34:22 PM »
I have an 06 LX 4cyl 58k mi. The rattle sounds like metal to metal like a drum roll. Sometimes all is good but sometimes its worse. This happens sometimes when i brake. It also happens when i park my car on a decline (my driveway) in D or R and my ebrake on. i pop the hood and my engine is shaking quite a bit. once i put it back in N or P it seems fine. I have recently changed (after the fact) my oil, spark plugs, transmission fluid, and air filter. my idle seems stable and car runs smooth while driving normally. any help is much appreciated.
Anthony
Re: Engine RATTLE idle? mounts?
September 23, 2010, 09:06:18 PM »
I could be a mount. You might not notice the rattle when your driving because of road nose. I have about 88k on my V6 and I've had a pair of mounts fixed/replaced.
September 23, 2010, 09:17:31 PM »
It does sound like a motor mount
September 24, 2010, 03:22:18 AM »
Look for fluid on or around your mounts. Like the consensus has already said, you have one or two bad mounts.
September 24, 2010, 08:20:08 AM »
Mine never leaked any fluid. I know its one of the symptoms but, mine were ripped up pretty bad and didn't leak.
September 24, 2010, 08:37:28 AM »
I had one go bad in the tsx, never leaked but stuff rattled pretty good
September 24, 2010, 11:04:17 AM »
May have leaked all the fluid out by the time you guys looked at them. Then again, not all of the mounts have damping oil in them. Who knows.
September 24, 2010, 11:43:06 AM »
i just replaced the rear mount on my i4 also because of the shaking on D... if you feel the dash shacking alot it maybe your rear mount thats bad..
September 24, 2010, 12:45:25 PM »
Quote from: CrackerTeg on September 24, 2010, 11:04:17 AM
They were still full homie.
phatmastaflip
September 24, 2010, 01:44:07 PM »
sounds good... i shall look more into getting new mounts. ill check back with you all later. any tips or links on changing mounts?
September 24, 2010, 03:01:03 PM »
Contact NVA-AV6 he can hook you up. He "repaired" one of mine, and saved me a ton of money
September 24, 2010, 03:37:37 PM »
Quote from: lavalleemike on September 24, 2010, 12:45:25 PM
Well then. I've never had one go out on me (knock on wood) and I wasn't there when yours went out. I'm just going by what's been told to others.
September 24, 2010, 05:39:30 PM »
One the J30 ones any way there is a dust boot on the top which may contribute to keeping the fluid inside. Mine were in two pieces lol
September 25, 2010, 05:55:34 AM »
Two piece mounts FTW!
September 25, 2010, 10:31:46 AM »
yeah thats how all my mounts were...in two peices FTL!!!
