August 30, 2026, 10:19:23 PM
help with "not an ashtray" compartment.
Topic: help with "not an ashtray" compartment. (Read 12118 times)
status
GOMD
June 29, 2010, 02:42:45 PM »
so i was trying to install the short shift i have, and pushed it down to open it and it sounded like something dropped. and now it wont shut.
-Alec
Re: help with "not an ashtray" compartment.
June 29, 2010, 02:58:22 PM »
you may have busted a spring
status
GOMD
June 29, 2010, 03:11:13 PM »
fixable? or just buy a new one?
-Alec
June 29, 2010, 03:28:48 PM »
It won't shut all the way or it won't move at all. In the photo it doesn't look like the rubber lining is sitting flat which makes it seem like the piece under it isn't clipped in all the way. Try to reseat the plastic piece.
June 29, 2010, 03:48:01 PM »
You probably don't have "not an ashtray" clipped in all the way.
stirfriedferret
June 29, 2010, 07:42:43 PM »
From the looks of the picture, Tim may be correct.
Brian
SoCalCM Squad
EliteCM Profile
June 29, 2010, 08:59:39 PM »
I've taken those things out and put them back in thousands of times, literally. Of course I'm right.
June 29, 2010, 09:05:30 PM »
I said it to god!!!!
June 29, 2010, 09:21:14 PM »
True that. You caught it first.
June 29, 2010, 09:51:11 PM »
Not a big deal I'd really like to see a post to see if this is actually what it was. That thing was a pain the first couple times I pulled it out now it's all loose (comes out easier).
status
GOMD
June 29, 2010, 09:56:07 PM »
i shook the fucker and slapped it and pounded it and nothing. ill try again.
-Alec
June 29, 2010, 10:01:55 PM »
You might have to pull it all back out. Take a look at the plastic clips in the very bottom and see what condition they are in.
status
GOMD
July 01, 2010, 11:12:47 AM »
didnt know you can pull it out... ill have to try that. its just the two screws by the shifter right and then pull?
-Alec
July 01, 2010, 11:36:20 AM »
Nope. Stick your fingers under the Not an Ashtray piece and you'll feel how it cups down. Just push up on that to pop out the cup. Those screws are part of what you need to take off to get the center console apart.
July 01, 2010, 01:21:09 PM »
Houston, we have a problem.
