September 30, 2026, 02:08:17 PM
KSport Coilovers
Topic: KSport Coilovers (Read 5966 times)
KSport Coilovers
June 11, 2010, 02:30:22 PM »
http://cgi.ebay.com/ebaymotors/03-07-Ho ... ccessories
Does anyone have any experience with KSport coilovers? These have pillow ball upper mounts on front and rear so no need for a camber kit out back...Any advice on these would be appreciated! I'm looking to be able to get low and have a decent ride, hence the adjustability on these. Thanks
Re: KSport Coilovers
June 11, 2010, 03:09:31 PM »
Quote from: "slipkord"
http://cgi.ebay.com/ebaymotors/03-07-Honda-Accord-Ksport-KP-Coilovers-CHD10-KP-_W0QQcmdZViewItemQQhashZitem45f3373715QQitemZ300433225493QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Pillowball mounts have nothing to do with whether or not you need a camber kit. You need a camber kit because Honda decided to give the Accord a better suspension design, but not to include adjustable camber. The
suspension design
of the Accord is what requires you to get a camber kit, not pillowball mounts.
Some coilover kits will include camber plates, but that is for MacPherson strut design.
June 11, 2010, 03:16:06 PM »
OK, well regardless of my incorrect statements, thanks for correcting me Mark. Does anyone know much about KSport. Reliablility/Warranty/Durability/etc...
June 11, 2010, 04:39:04 PM »
No problem.. just wanted to educate folks
I know people that have KSport. I'm not sure about reliability and durability, since I haven't asked people about them. Just an FYI, there's a good chance that the manufacturer will not warranty the product if purchased through eBay, especially if that eBay seller is not an authorized reseller.
June 11, 2010, 07:47:31 PM »
K-sport are to me are junk. My friend had them on his EJ8, and they blew out after 6 months. K-sports in general are too stiff. I'd rather get Tein Basics over any K-sport coilovers. This is just my 2 cents.
June 11, 2010, 07:53:19 PM »
After research I've heard the same thing Thien
June 11, 2010, 10:52:36 PM »
I wouldn't go with the K Sports Jeremy. You know the deal with the Tein Basic's though. I'd get them instead.
Nexson
June 11, 2010, 11:53:11 PM »
I have had tein stechs with koni yellows, I have ground controls with koni yellows, I then had tein SS, now I have Ksports.
Ksports by far have the best ride. All the previous suspensions bottomed out to often and had a rough ride, even the SS at times. With the way that the ksport shock adjusts, it helps to the car to not bottom out because the spring is pre-loaded. Ksports really adjust weird, to adjust height, you have to release the rear seat on the front and rear, a little bit of a pain, but once you set the height, your good to go. You adjust the height by moving the whole shock up and down on the threads.
It took me about 2 weeks to play around with it, but the ksports by far have had the smoothest ride, they glide over bumps, and the big loud thumb is a thing of the past in most cases.
June 12, 2010, 12:21:27 AM »
Quote from: "Nexson"
Bottoming out is a consequence of your compression and your rebound being too soft. That means it's compressing too fast and is not rebounding fast enough.
Unfortunately, all your setups included one-way shocks. You could adjust compression and rebound together, but not separately. You may have had them set too soft.
All of your setups also included the spring being preloaded. Unless, of course, you dropped the car too low. You start losing preload when you go too low, and you completely lose it when the spring rotates freely when the suspension is drooping.
Bottoming out is a factor of spring rate, compression, and rebound; more so the shock damping. If the K-Sports have a higher spring rate, they more likely are damped stiffer, which could be the stiffer damping that helps to not bottom out.
I'd actually like to see a shock dyno on the K-Sports; more than likely, a shock dyno on the K-Sport shocks will show the shock to be substandard.
