August 25, 2026, 04:08:26 PM
Detailed: 2008 Chevrolet Tahoe - 20k Mile Nightmare!
Topic: Detailed: 2008 Chevrolet Tahoe - 20k Mile Nightmare! (Read 3543 times)
June 10, 2010, 05:19:05 PM »
This 2008 Chevrolet Tahoe, looked tired and aged, which was unacceptable being a 2008 vehicle with only 20k miles on it! We could see the damage from the other end of the building when we showed up, the black paint had a heavy gray hue to it. Over the course of 25 hours among three of us working, we revived this paint and gave it the gloss and correction it should have regardless of age and mileage! Being such a large vehicle, we had our work cut out for us, and it's not often that we do SUVs simply because of the time and effort required to do such extensive correction work. As listed in the process the paint varied across the vehicle, and some panels were more damaged than others, a result of consistent trips to the automated car wash. Just goes to show, hand washing your vehicle is far more beneficial in the long run. This was easily one of the most defected vehicles I have worked on in the last 6 years, I've tackled some difficult projects before that consumed many days, but this Tahoe takes the cake on damage, lucky for us paint was pretty soft and easy to fix. With that said, the pictures are worth an unlimited amount of words, there are a LOT of pictures in this thread, but we really wanted to document and show the differences in the various lighting and such. Even in the shade this car made me cringe!
Products used
Meguiar’s M105 + wool pad
Meguiar’s M105 + yellow pad
Menzerna SIP + yellow pad
Menzerna 203PF + orange pad
Menzerna 106FA + black pad
Blackfire Wet diamond + blue pad
P21S Paint Cleanser + P21S yellow applicator
Meguiar’s Last Touch (clay lube)
Riccardo yellow clay
Sonus Green superfine clay
CG maxi suds
Poorboys Bold ‘n Bright tire dressing
Poorboys Natural look
Procedure:
Car was rinsed and washed with CG maxi suds, there was no protection on car what so ever. After wax, it was dried and clayed, it was pretty bad specially on lower section of doors and rear hatch. Car was washed again and dried. Pulled car inside, and took paint readings, range was from 95-105 to 298-334 on same panels. Test panel was done on hood and Menzerna 203 and orange pad took everything out with one stage. Other panels needed more work and different combinations of pads and polishes were used. After all polishing stages (3 stages), P21S paint cleanser was used and then BlackFire sealant was applied, left on car for about an hour and wiped off. Wheels were cleaned , tires dressed, plastic trim dressed. Tail lights and headlights were polished. Glass cleaned.
Time spend on detail: 25 hours
Onto pictures
Before
15
20
Clay condition after about each panel
bottom of doors (this was about same after each door)
25
Top panels
test panel 50/50
30
Correction pictures 50/50
35
40
45
50
car was pretty big so all means of getting job done were used
50/50 video of rear quarter panel after first polishing stage
55
BlackFire sealant applied
reflection pictures
60
65
70
75
Final pictures and video
80
85
90
95
The end results speak for themselves! Thanks for reading!
konatriathlon
Re: Detailed: 2008 Chevrolet Tahoe - 20k Mile Nightmare!
June 13, 2010, 05:01:49 AM »
Wow! An amazing difference just after the clay bar. Nice work. Chevy has really made the new Tahoes look hot with the new body stile. This one in black after you finished just sizzles. Nice restoration.
HARPER BELLE HANES
Born: 04/04/2008
5 lbs 2 oz
17 1/2 in
JASPER PARKE HANES
Born: 03/09/2010
6 lbs 15 oz
19 3/4 in
June 13, 2010, 10:31:58 AM »
there is no difference after clay bar as far as finish, it just takes off contamination, most of time it makes finish worse depending on aggressiveness of clay
