January 30, 2026, 02:59:42 AM
Author Topic: D2 Suspension Review.  (Read 4146 times)
MuGEN7Accord
BANNED
MuGEN7Accord is looked down upon.
« on: May 16, 2010, 12:48:21 PM »
Best suspension ive ever purchased, worth every penny easy to install also.
I do recommend this to anyone looking to lower your car!
Dont do the spring, just spend the money once and the right way!
You can control how stiff you want the ride and it does get really low.
« Reply #1 on: May 16, 2010, 09:59:53 PM »
Ummm, okay.
« Reply #2 on: May 16, 2010, 10:59:03 PM »
Wait a minute.  What are the spring rates for these?  I remember riding in a guy's car that might have had these and they were unbearably stiff.  The dampers were set to full hard, so that contributed to the stiffness in the ride.  Are yours uncomfortably stiff too?
Reputation Power: 18
alpha pfffft.
« Reply #3 on: May 16, 2010, 11:41:27 PM »
Would you be able to provide more details in your review?  Spring rate? Number of damping clicks? How the shock valving feels?  Adjustment range?
MuGEN7Accord
BANNED
« Reply #4 on: May 17, 2010, 07:09:40 AM »
The spring rates are set from stock out the box but i adjust mine and they are not uncomfortable and my car is slammed so its set on super stiff, I might raise it can try semi soft.
But these take bumps like a champ.
I almost forgot i was lowerd, going from spring suspension
Quote from: "alpha"
D2 Racing Coilovers Feature:
•Fully adjustable (36-way dampening(51mm shocks), and ride height)
•Custom spring rates (3.5, 5, 7, 9, 11, 13, 15, 18, and 22 kg/mm)
•Pillow ball mounts included w/ camber plates!
•Telflon-coated threads
•Flawless CNC finish
•2 Keys for adjusting ride height
•Carefully matched spring and damper rates
•1 year warranty
« Reply #5 on: May 17, 2010, 08:13:13 AM »
Spring rates are not adjustable.  Your damping is adjustable though.  To change the spring rates, you would have to change the springs.  It seems that you can order different spring rates from D2 though.  What are the spring rates of your springs?
Asim pfffft.
« Reply #6 on: May 17, 2010, 11:40:40 AM »
these should be identical to BC racing, megan
