June 15, 2026, 11:54:32 PM
Author Topic: New Shoes and not from Payless!!  (Read 13108 times)
Reputation Power: 18
alpha pfffft.
« Reply #15 on: May 06, 2010, 01:21:47 PM »
Quote from: "k24low20z"
Quote from: "Milan"
Love the new set-up but I can't believe you can get away with that offset!  How much camber are you running in the back?  I'm only 19x8 +30 in the back with the fenders rolled yet I still rub.  Can you take a picture of where the quarter panel meets the bumper?  That's where I'm rubbing really bad and I can't seem to get the fender rolled any more.  How bad do you rub in the front?  With a 45mm offset and a slight pull I still rub over dips.
im running stock specs camber in the back with the wicked camber kit..and the front is stock without any camber kit. the reason that you are rubbing is because of the 30+ in the back..im running +40 for the back on a 9.5 wheel so it sits deeper in the wheel well oposed to the 30+ causing it to stick out more..also remember i had 20x8.5 and i had to shave off part of the inside of the bumper were it meets the quarter panel just a bit..so it was able to clear those.. and in the front im about 1/4 inch pass the fender but it dosent rub at all i only pushed back the tab for the fender liner and called it a day..
Your setup is still 9mm more aggressive than Milan's..
Milan, are you rubbing on the bumper tab? Have you shaved any part of your rear bumper?
k24low20z pfffft.
« Reply #16 on: May 06, 2010, 08:20:44 PM »
here are some what better pics..im nnot sure why milan is rubbing so much..
Milan pfffft.
« Reply #17 on: May 06, 2010, 09:18:36 PM »
Quote from: "alpha"
Yep, Alex's set-up sticks out 9mm more because of the wider wheel.
I bent the bumper tab, that's not the issue anymore.  I'm rubbing on the part where the bumper and the fender meet.  I can't get it rolled flat enough.  Me and Jason will have to try again I guess lol!
clapton924 pfffft.
« Reply #18 on: May 06, 2010, 09:54:22 PM »
Hmm...that metal-look trim kit is nice. I've been thinking about buying it for a while....might pull the trigger now I've seen it.
k24low20z pfffft.
« Reply #19 on: May 06, 2010, 11:51:01 PM »
Quote from: "Milan"
Quote from: "alpha"
milan ill try to get some pictures of where the bumper meets the quater panel so you can see where i had to shave it down..
alpha pfffft.
« Reply #20 on: May 07, 2010, 03:38:05 AM »
Quote from: "Milan"
Quote from: "alpha"
You may have to do some cutting.. and not ghetto roll the fender, lol..
Reputation Power: 11
sherker55 pfffft.
« Reply #21 on: May 12, 2010, 09:57:42 PM »
Quote from: "v6sicksspeed"
what are the left thumb controls on the steering wheel?
+1
Asim pfffft.
« Reply #22 on: May 13, 2010, 11:29:54 AM »
Quote from: "sherker55"
+1
One is the talk button for nav, other is back button for the menu's
Pages: « First 1 [2]   Go Up
