August 05, 2026, 06:29:14 PM
Steering Play
Topic: Steering Play (Read 10486 times)
Steering Play
April 09, 2010, 12:05:08 PM »
I've noticed that my steering has become a little vague. For example, I can move the steering wheel about 1" side to side without the wheels turning much. This also affects tracking a straight line. There is no play in the wheels if you push/pull on them at 12 and 6 positions. Could my bushings be going bad?
Re: Steering Play
April 09, 2010, 01:12:47 PM »
Its possible. Have you inspected them at all? What about your ball joints?
Re: Steering Play
April 09, 2010, 02:13:20 PM »
I would suggest a detailed inspection of your front suspension. There should be a little play but, off the top of my head an inch sounds like alot.
Re: Steering Play
April 09, 2010, 02:33:21 PM »
Have not inspected ball joints or bushings. Just trying to get an idea of what might be wrong before I get under the car.
What about tie rods?
Re: Steering Play
April 09, 2010, 07:13:32 PM »
It's possible the ball joints wore out in your tie rods.
Re: Steering Play
April 09, 2010, 08:27:31 PM »
Quote from: "clapton924"
Checking for steering play should be at 3 & 9, 6 & 12 is for ball joints.
Now if there still is no play but you still have a good 1"+ of wheel play then it could be the rack....
Re: Steering Play
April 09, 2010, 09:58:52 PM »
Quote from: "NVA-AV6"
When I put my summer wheels back on a week or so ago I did the 12 & 6 check: no movement. I guess that rules out the ball joints.
Correct me if I am wrong, but if you push/pull at 3 & 9 won't the wheel naturally move since the car is jacked up?
Re: Steering Play
April 09, 2010, 10:03:52 PM »
Yes, it would, but you are feeling for like a popping or slight clunk type of play. If and when you feel those type of play, it will indicate a loose tie rod end. Either the inner or outer.
Re: Steering Play
April 09, 2010, 10:07:58 PM »
Ok, I will check for those types of sounds. I have a feeling its going to be the rack...which I know nothing about!
Re: Steering Play
April 09, 2010, 10:12:45 PM »
Its really not a sound, but more like a movement. Like a pop or clunk movement. Have you had your alignment done lately?
Re: Steering Play
April 09, 2010, 10:28:34 PM »
yeah, I've had an alignment in the last 6 months.
I did some reading, I think I need to tighten whats called the "rack guide screw".
Re: Steering Play
April 10, 2010, 07:40:46 PM »
Just checked the movement of the wheels from 3&9 positions. Wheels move smoothly....there is a slight noise when the wheel hit the max turn-in angle...but I think thats probably normal as it hits a "stop" of sorts.
Referring to my How-to thread - My measured rotational play is ~46-50mm. Well off the 10mm limit.
I jacked up the car today and found the rack guide screw....holy crap is it in a tight spot....I have no clue how they expect you to fit a torque wrench in there!
wai_pang2
Re: Steering Play
February 12, 2011, 12:20:06 AM »
Hi everyone
to the OP; I would do what Crackerteg said to check. My car would wonder when ever I went over rough roads or bumps. I had the same problem for a long time and this past 2 weeks, I replaced majority of my suspension which consisted of shocks, springs, upper/lower balljoints, outer tie rods and front and rear camber. When I had my friend press out my lower ball joint, I noticed the ball looking thing had play in it. I have approx. 150K on all those parts, the rubber boots on the ball joints were ripped.
Re: Steering Play
February 12, 2011, 05:13:30 AM »
Um, k. A little late but um, sure. For the record, it was Paul and Thien that gave better responses. I'm not taking credit for that.
