November 06, 2026, 05:18:16 PM
Axle assembly - MT vs AT
Topic: Axle assembly - MT vs AT (Read 10070 times)
Sworkhard
April 02, 2010, 12:20:30 PM »
Does anyone know if there is a difference between the left and right axle assemblies for automatic and manual transmissions. I've tried looking on Honda parts websites but I can't seem to find what I'm looking for. The reason I ask is I can find several assemblies available in Canada but they are listed specifically for the automatic where the parts websites based in the states don't seem to specify a transmission.
Thanks,
Stephen
[size=150]Stephen[/size]
03 Accord EX-L 5MT
Re: Axle assembly - MT vs AT
April 02, 2010, 12:55:52 PM »
Majestic Honda shows 2 different part numbers for each side, and each transmission type. I would assume based on this information that they are different. Diagrams can be seen here.
AT Diagram
MT Diagram
AT Right = 1088897, and 1094431
AT Left = 1088900, and 1094433
MT Right = 1088898, and 1094432
MT Left = 1090954, and 1094434
This site does not use Honda part numbers*
Sworkhard
April 02, 2010, 03:28:21 PM »
Thanks. That's what I needed to know. I've found some that specify the mt now at autozone, so I ordered those..
03 Accord EX-L 5MT
April 09, 2010, 01:07:22 AM »
^Good idea. There is a difference between the MT and AT axles. I was sold a set of AT axles (I was not told) and found out later that they do not fit an MT equipped car.
April 09, 2010, 08:42:36 AM »
What was different the number of splines?
April 09, 2010, 09:56:16 AM »
The AT was smaller than the MT. From what Paul explained to me yesterday, I belive this only applies to the K24s.
April 09, 2010, 10:00:24 AM »
I have no issues with axles I was just asking to get a perspective for the future.
April 09, 2010, 11:39:48 AM »
I understand. I was just throwing that out there for general info.
Sworkhard
April 26, 2010, 04:52:27 PM »
I ended up going with raxles (raxles.com) since the ones from autozone looked really cheap and didn't come with harmonic dampers. The raxles seem like a much higher quality product.
03 Accord EX-L 5MT
asnstyle22
April 26, 2010, 05:04:01 PM »
how much did it cost for the raxles? i was gonna go driveshaft shop for some stronger axles
Sworkhard
April 28, 2010, 01:37:37 AM »
IIRC they were $140 each. Not sure if they are any stronger than oem, but they are definitely better than the cheap cardone axles.
03 Accord EX-L 5MT
