November 06, 2026, 11:14:45 PM
524
525
526
527
Topic: What did you do to your Gen7 today? (Read 3817674 times)
0 Members and 13 Guests are viewing this topic.
Reply #7860 on:
August 10, 2014, 11:41:40 PM »
Installed my fuel pump today. I also started running the feed line and re-routed the return line so it's not half assed like it was before. I also spent some time fitting and securing my water tank for my aftercooler system. I stopped by my welder's house today and helped him figure out the dimensions for the end tanks on the aftercooler in the plenum. Tomorrow I should be getting a major piece for my build and then things can hopefully can start moving along a little faster.
Reply #7861 on:
August 15, 2014, 01:17:16 PM »
Finally got a car mount for my phone. Went with the RAM mount style and made my own bracket to attach to the dashboard. None of the drilled holes are visible from the outside so I can still remove it later.
https://www.dropbox.com/sh/8s4y9cvqkwyn33n/AAC-I7ZXReCc1a0dpKixYaGAa
Reply #7862 on:
August 15, 2014, 08:07:30 PM »
Looks pretty good Jeff
Reply #7863 on:
August 17, 2014, 04:27:05 PM »
Changed back to my old wheels. See my post in the tires and wheels thread.
Reply #7864 on:
August 17, 2014, 07:44:32 PM »
Last night I upgraded my springs on the shift mech on my transmission to the MTEC Race Springs. Today, I finished running my fuel feed line, attached my fuel lines to my pump and wired up the fuel pump to the relay. I also mounted the water tank, attached the water lines from the tank to the bulkhead fittings out of the trunk and ran the water return line from the heat exchangers. I may get around to making new fan mounts for my radiator later tonight.
Reply #7865 on:
August 18, 2014, 11:10:58 AM »
I finally got the courage to tackle my AT filter replacement and got it done. It wasn't nearly as bad as I thought it would be.
Reply #7866 on:
August 18, 2014, 03:22:40 PM »
Nope. AT filter replacement is cake.
Reply #7867 on:
August 23, 2014, 12:03:38 AM »
Well yesterday I started pulling my cup holder/shifter bezel out and seeing what needs to be done to fit the TSX parts in. The cupholder is noticeably bigger and some of the tabs don't line up. Also, the Accord heated seat switches are smaller and float around in the TSX bezel. The connectors look the same so I'm on the hunt for heated seat switches. I also had an oil change and a check up and all is well. I also found out that I have the wrong TSX IM.. It's OK (thanks Tim) on the hunt for that as well.
Reply #7868 on:
August 25, 2014, 04:24:10 PM »
Ordered TSX heated seat switches from AFH parts. Fingers crossed they fit and work!!!
Reply #7869 on:
August 25, 2014, 05:14:57 PM »
cried cuz some ass hole in a red car/truck left a nice red mark on my rear driver side door
Last Edit: August 25, 2014, 07:30:00 PM by thisaznboi88
Reply #7870 on:
August 25, 2014, 05:42:47 PM »
Did a bunch of stuff over the weekend that nobody would give a shit about.
Re: Re: Re: What did you do to your Gen7 today?
Reply #7871 on:
August 25, 2014, 09:12:55 PM »
Quote from: timot_one on August 25, 2014, 05:42:47 PM
Bullshit.
Reply #7872 on:
August 25, 2014, 10:03:19 PM »
I care!!!!!!!
theycallme_og
not that kind of OG
Reply #7873 on:
August 26, 2014, 12:04:53 PM »
got a new windshield..
Reply #7874 on:
August 26, 2014, 09:34:53 PM »
I ran the fuel lines and water lines. I also worked on a few things with my engine wire harness to add a boost by gear solenoid and a solenoid for my water methanol injection. I painted the front heat exchanger black with radiator paint.
All stuff not many people on here would care about. It's not as cool as some new rimz or painting my plastic engine cover though.
524
525
526
527
