September 29, 2026, 09:11:16 PM
369
370
371
372
Topic: What did you do to your Gen7 today? (Read 3747058 times)
Reply #5535 on:
September 24, 2012, 12:49:33 PM »
This happened over the weekend, starting Friday and ending Sunday. Installed AMRs and Junk2 front camber arms. Adjusted the height to my liking. DIY alignment.
Surprisingly, the alighnment is pretty straight. Definitely way better than what it was when I had is professionally done at a shop (i.e. the damn car always drifted right, noticeably). Finally lower; I haz happy.
Reply #5536 on:
September 24, 2012, 12:59:07 PM »
Reply #5537 on:
September 24, 2012, 06:07:57 PM »
Reply #5538 on:
September 25, 2012, 11:16:13 AM »
Order me some new brakes from r1concepts , Going take the time to install my ss, brake lines while at it
ubermike
Reply #5539 on:
September 25, 2012, 11:43:44 AM »
I did the mod to enable A/C control when the defroster is selected.
I couldn't figure out why my A/C was running when the LED was off and I was getting pissed about it! lol. Even when I started it cold, the radiator fans would kick on which bugged the shit out of me. Then it would cycle every few min causing a droop in engine power and dimming the headlights for a second. Sure, I could have selected something other then defrost and leg vents, but that's my favorite setting for heat! I'm glad I found the fix.
Reply #5540 on:
September 25, 2012, 12:00:04 PM »
Details or link? I can't remember if I've heard of this mod before.
ubermike
Reply #5541 on:
September 25, 2012, 12:18:18 PM »
1. Insert key into ignition
2. Press and hold A/C and Recirculation buttuns
3. Keep holding and turn ignition to position [II]
4. Keep holding for about 10 sec, you'll notice A/C light will flash for a few seconds. Do not release untill finished flashing.
Link
Now the AC light comes on when selecting either defrost mode and the A/C can be shut off. My understanding is that normally when a defroster mode is selected, it will turn on the A/C and the button will not control the A/C. LED on or off it will be running.
oh3ex
Reply #5542 on:
September 25, 2012, 02:47:46 PM »
Slapped on my new shifter today, needs some tweaking but it'll do for now.
Reply #5543 on:
September 25, 2012, 02:58:32 PM »
Now that's funny.
Reply #5544 on:
September 25, 2012, 05:58:14 PM »
I love the rabbit with the stache lol
Reply #5545 on:
September 26, 2012, 12:14:44 PM »
Does the defrost without a/c setting allow you to disable the compressor? I'm familiar with the setting change, but not as familiar with how it affects the a/c system/compressor. If this disables the compressor (disengages the compressor clutch), it means that you defrost/defogger is also disabled.
Ohh yeah. Not a fan of the "shift knob". The bunny with the mustache would have been a better choice.
Reply #5546 on:
September 26, 2012, 02:47:36 PM »
Quote from: timot_one on September 26, 2012, 12:14:44 PM
Ac is not needed to defrost. It aides but is not required.
Reply #5547 on:
September 26, 2012, 06:09:17 PM »
Got this done today, sorry for the picture quality. Its kinda hard to take a picture of a mirrored surface in the dark.
Are you a fan of this shift knob Tim...
Last Edit: September 26, 2012, 06:11:37 PM by Rich01
Reply #5548 on:
September 26, 2012, 07:05:59 PM »
Is that a grip on the front side of it?
Reply #5549 on:
September 26, 2012, 07:53:28 PM »
No, just a reflection of the interior. It was stripped, polished & buffed (to get out some dings from having my key chain hitting it when get in the car) and then a 3 step process with the end result being an electro nickle-chrome plating, if i remember correctly.
369
370
371
372
