June 16, 2026, 10:22:50 AM
338
339
340
341
Topic: What did you do to your Gen7 today? (Read 3570455 times)
0 Members and 24 Guests are viewing this topic.
Reply #5070 on:
June 28, 2012, 07:56:53 AM »
Ohhhhh, thanks for clearing that up Z
Last Edit: June 28, 2012, 11:43:23 AM by Arielit0oo
Reply #5071 on:
June 28, 2012, 08:46:58 AM »
That's what I'm here for.
Reply #5072 on:
June 28, 2012, 09:27:41 PM »
I'm selling my TSX mirrors for $250 shipped. That's OBO though. I'm open to reasonable offers.
Reply #5073 on:
June 28, 2012, 11:46:01 PM »
Trying to figure out why my driver heated seated seat won't turn off , in a.mission to find where the relay is located
Reply #5074 on:
June 29, 2012, 12:58:57 AM »
Quote from: cna on June 28, 2012, 11:46:01 PM
Did you swap the switches and see if its the switches?
Reply #5075 on:
June 29, 2012, 01:39:28 AM »
yeah swap switches still same issue , pull fuse didt help still stays on and with this weather driving me crazy
Reply #5076 on:
June 29, 2012, 08:45:37 AM »
Your 100% positvie its on right. If you pull the fuse there should be no power, and the heater shouldn't be able to work without power.
Reply #5077 on:
June 29, 2012, 12:36:01 PM »
Quote from: Mike on June 29, 2012, 08:45:37 AM
yeah its only my driver seat with the issue the passenger seat is fine even after fuse was pulled i still get heat off it . i think there's a relay from what i research but not 100% positive of the location
Reply #5078 on:
June 29, 2012, 01:00:28 PM »
Drive around with the seat unplugged and see if its hot. Sometime mine feels like its on but, its not. Tough to expalin but, I've def. thought it was on in the past.
Reply #5079 on:
June 29, 2012, 01:06:27 PM »
i have left my car running while testing my audio and with out sitting on it you can feel the heat once you touch it with your hands compare to the passenger side, i found 2 relays behind my glove box but not sure if its for the seats , today am a take my multimeter and poke around just to be positive its getting some type of voltage
Reply #5080 on:
June 29, 2012, 04:21:24 PM »
put in my new sway links and rear 20mm bushing
greasable links for 30 a pair on amazon FTW and its beefer then honda crap
Reply #5081 on:
July 05, 2012, 11:39:51 PM »
Drooped the car off at the shop to fix/paint my front end, install my OEM Front lip, new headlights, inspire fogs(when they get here) and TSX Mirrors
Last Edit: July 06, 2012, 12:13:35 PM by Arielit0oo
Fanitron
Reply #5082 on:
July 06, 2012, 09:21:12 AM »
Quote from: thisaznboi88 on June 29, 2012, 04:21:24 PM
Those look almost identical to the Moog links I put in last week. Gonna be installing my 20mm swaybar as soon as it arrives
Quote from: Arielit0oo on July 05, 2012, 11:39:51 PM
Drooped the car off at the shop to fix/paint my front end, install my OEM Front lip, new headlights and TSX Mirrors
^^Jelly
Reply #5083 on:
July 06, 2012, 09:43:13 AM »
Stop copying me. Nobody goes to the body shop as much as I do except for Alex.
Reply #5084 on:
July 06, 2012, 10:48:51 AM »
Ha!
338
339
340
341
