October 01, 2026, 02:18:01 AM
Pages: « First < Previous 1 ... 333 334 [335] 336 337 ... 596 Next > Last »   Go Down
Author Topic: What did you do to your Gen7 today?  (Read 3748968 times)
0 Members and 18 Guests are viewing this topic.
« Reply #5010 on: June 11, 2012, 10:26:50 PM »
cleaned replacement headlights in prep for retro... found a crack on driverside rear housing just near the highbeam Sad hopefully I can just seal it up after and it will not affect anything. Gonna have to be real careful pulling it apart though
JB WELD IT! its only on the black plastic part right? Just JB WELD it inside and outside.
CYANiDE pfffft.
« Reply #5011 on: June 12, 2012, 06:05:42 PM »
Got my rear camber arms in finally. Then had to head to a shop for an alignment ASAP. Ended up spending a couple hundred more bucks to get my car how I wanted at the end, but I guess it comes with the territory of modding cars.  Flippa!
Reputation Power: 11
Armyguy239 pfffft.
« Reply #5012 on: June 12, 2012, 06:11:34 PM »
watched it gettin taped up for the sand down this morning.... they filled in the keyed up parts, and fixed the dents yesterday:)
Fanitron
Fanitron pfffft.
« Reply #5013 on: June 12, 2012, 08:00:41 PM »
Yes just the black housing on the back. I'm gonna JB Weld it once I have it apart and sand it smooth, probably won't even know it happened once it's done... problem is I hope it doesn't crack more when I try to pry it apart  Embarrassed
« Reply #5014 on: June 12, 2012, 09:48:05 PM »
as long as it doesn't shatter your okay. crack is nothing. I fixed cracked ho using before for one of my customer with JB. he said it never leaked.
« Reply #5015 on: June 13, 2012, 06:15:00 AM »
Got to NC the other day and hit my fenders with a fender roller. They were in need. Hitting the road again today.
« Reply #5016 on: June 13, 2012, 04:06:32 PM »
need to get another rear alignment since firestone can't do it on my aftermarket camber kit... mother Fker rear toe is off by 2x what the max is. camber is almost 2* off what it should be...
« Reply #5017 on: June 13, 2012, 06:40:04 PM »
Firestone can do the alignment. They're just too lazy to do it. Go back and demand a refund for your lifetime alignment and they'll do it.
« Reply #5018 on: June 13, 2012, 08:41:06 PM »
Will do. I wish Thien worked at this firestone. Then I can get custom specs.  >Cheesy
« Reply #5019 on: June 13, 2012, 10:59:34 PM »
I've brow beat them into setting up my car the way I wanted it.  It's all about being persuasive.  At the Firestone I went to in MA, I didn't allow them to take advantage of the situation.  Yes, I was an asshole to them.  I went there a lot and I got them to align it to the specs I wanted.
« Reply #5020 on: June 13, 2012, 11:05:04 PM »
I took off my UR rear 4 point chassis brace, took off my j-pipe, took off my test pipe, took off my Endless BBK, installed stock j-pipe, installed stock 3rd cat, and installed 06 TL front calipers, pads, rotors, and SS lines.
 Cry Cry Cry Cry Cry Cry Cry Cry Cry Cry Cry Cry Cry Cry Cry Cry Cry Cry Cry Cry Cry Cry
Fanitron
Fanitron pfffft.
« Reply #5021 on: June 15, 2012, 05:39:27 PM »
I wanna pull my intake manifold cover to paint... but was wondering if I would need to get a replacement gasket for when it goes back on? question
status
GOMD
status pfffft.
« Reply #5022 on: June 15, 2012, 05:49:44 PM »
used turtle wax product thing to restore headlights, at first I thought I was fuckin shit up, but seems to have worked well.
 also cleaned out all the dirt and mold in the trunk water runoff nasty as hell.
-Alec
« Reply #5023 on: June 15, 2012, 08:21:10 PM »
If your car is a 6 you can reuse the gasket its metal just don't break it
« Reply #5024 on: June 16, 2012, 12:07:57 AM »
Paited my Cusco Type 2 Lower Front Arm Brace red and detailed her up
Pages: « First < Previous 1 ... 333 334 [335] 336 337 ... 596 Next > Last »   Go Up
