February 01, 2026, 04:18:33 PM
33
34
35
36
Topic: What did you do to your Gen7 today? (Read 3261740 times)
Reply #495 on:
April 21, 2009, 10:19:50 PM »
flush the power steering
Reply #496 on:
April 22, 2009, 11:39:56 AM »
Painted trim pieces under hood last night, radiator shroud, engine cover and fuse box cover.
DV8mAn
I'm Tired...
Reply #497 on:
April 22, 2009, 02:19:13 PM »
New Tires
MuGEN7Accord
BANNED
Reply #498 on:
April 22, 2009, 06:07:19 PM »
just ordered parts straight from Japan!!
no more money issuessss, the recession is over
Reply #499 on:
April 22, 2009, 09:20:59 PM »
i personally didn't do anything, but Paul took off the heads, installed the new heads with cams and raised compression and wrapped it up for today. tommorow he'll be building everything back together, refill coolant and other vital fluids for the vehicle.
Reply #500 on:
April 22, 2009, 10:24:59 PM »
oiled the seats
skizot
Reply #501 on:
April 22, 2009, 10:38:12 PM »
Washed, waxed, vacuumed, pulled out the carputer, put back in the stock lower cubby and pulled out all the cabling from the carputer. Removed my PLX device as well. This took forever. I really did a great job of zip tying everything in . Man I was sweating in this Florida heat today. Anyway, it is all out and back to a stock interior, minus the Navi upgrade I did.
Reply #502 on:
April 22, 2009, 10:41:08 PM »
Quote from: "cna"
oiled the seats
with what?
Reply #503 on:
April 22, 2009, 10:59:15 PM »
Installed Cusco Lower Chassis Brace, and reparked in the garage, too much Rain, it has been pooring in NY for the last 3 days straight.
Knocturnal84
Reply #504 on:
April 23, 2009, 10:19:59 AM »
washed the car .....might have to think about that cusco lower brace
Sean Artsen
BrianCrower K24
Reply #505 on:
April 23, 2009, 10:23:11 AM »
Put the rims back on, washed it up, FK 425'ed the whole thing and finally used my SC Voodoo on the leather. Yeah, it works great! Also realized that our car aint the lowest but damn it's low. I had to drive it up on to 2x4's in order to get enough clearance for the floor jack!
Reply #506 on:
April 23, 2009, 05:11:51 PM »
I detailed my car for a few hours while Paul was wrapping up the P&P heads w/raised compression, and TL-S cams.
suleman_manji
Reply #507 on:
April 23, 2009, 11:09:48 PM »
Serpentine Belt; this morning when I was doing my random morning check I noticed a tiny tear starting to appear on the middle of the belt.
T
X
Squad #
flick
r
fb
[img]http:
Reply #508 on:
April 24, 2009, 12:28:25 AM »
Cleaned my rims inside and out, while I had them off the ride I sanded and cleaned my calipers and painted them lime green. I also painted some trim pieces under the hood and in my trunk. Then gave the ride a good clean wash! When I got home from work tonight I helped tape up my brother's civic so we can lay down the last coat of pearl white, after about an hour we applied the 1st clear coat with sparkles. Tomorrow morning it gets the second coat of just clear. In the afternoon the last coat of clear goes on and we are officially done! The car is looking amazing for some work done in a tent in our backyard!
Can't wait for the car show in PA this sunday!
Last Edit: April 24, 2009, 12:57:26 AM by CrazyCreashunz
Reply #509 on:
April 24, 2009, 12:31:38 AM »
painted front caliper braket. put shims back on, just ordered rear brake pads couse dont know if mine will pass inspection on tuesday
33
34
35
36
