May 31, 2026, 10:09:37 AM
306
307
308
309
Topic: What did you do to your Gen7 today? (Read 3537186 times)
Reply #4590 on:
March 21, 2012, 08:31:43 AM »
Having the sensor unplugged from the master brake resevoir under the hood won't cause me to fail my inspection right.... I don't think it should but I rather be 100% sure! Going for inspection on my day off tomorrow.
Reply #4591 on:
March 21, 2012, 08:39:45 AM »
Depends on whether they look under the hood and if there is a dash light on. Just for shits and giggles, can you post a picture of where the sensor is at and which dash light is on when it is plugged in?
Reply #4592 on:
March 21, 2012, 02:53:50 PM »
It is the light that normally comes on when you engage the e-brake. It lights up "BRAKE" and the sensor plug is literally on the back end of the resevior. I'm at work so posting a picture won't happen lolz. I pretty sure I will be ok as the "CEL" is NOT on!
Reply #4593 on:
March 21, 2012, 03:34:17 PM »
Quote from: CrazyCreashunz on March 21, 2012, 02:53:50 PM
I know in RI the brake light will fail you because it indicates that there is an issue with a safety mechanism.
Reply #4594 on:
March 21, 2012, 03:41:21 PM »
Quote from: CrackerTeg on March 19, 2012, 09:58:47 AM
Ordered new energy suspension bump stops to combat the control arm slap I get on hard bumps.
What bump stops did you go with? I can't find 'em!
Last Edit: March 21, 2012, 03:46:34 PM by CYANiDE
Reply #4595 on:
March 21, 2012, 07:26:36 PM »
These:
http://www.amazon.com/gp/product/B002M5P06K?ie=UTF8&ref=aw_bottom_links&force-full-site=1
I also pulled my front fenders a bit more today. Needs that clearance dawg!
Reply #4596 on:
March 21, 2012, 08:46:28 PM »
I cleaned off the hubs of the rotors and sprayed them flat black with BBQ paint. Ready for another summer. Also adjusted my projectors so then no longer shine above horizontal.
Reply #4597 on:
March 21, 2012, 09:19:39 PM »
Does the dash light still work with your parking brake?
Last Edit: March 21, 2012, 09:28:22 PM by timot_one
Reply #4598 on:
March 21, 2012, 10:01:37 PM »
Quote from: timot_one on March 21, 2012, 09:19:39 PM
Yes dash light still works with the e-brake even though the sensor plug is taken out.
Last Edit: March 21, 2012, 10:28:02 PM by CrazyCreashunz
Reply #4599 on:
March 21, 2012, 10:11:34 PM »
tucking wires in my trunk to make room for the sub box
Reply #4600 on:
March 21, 2012, 11:51:39 PM »
Quote from: CrazyCreashunz on March 21, 2012, 10:01:37 PM
You should be fine then. Just try to hide the unplugged connector if they do a visual inspection under the hood.
Reply #4601 on:
March 21, 2012, 11:56:01 PM »
Ok sounds good to me... Thanks Tim!
Reply #4602 on:
March 22, 2012, 12:00:36 AM »
No problem Billy. Time to find that replacement sensor though.
Reply #4603 on:
March 22, 2012, 12:30:33 AM »
Yea its literally inside the resevior bottle that holds the brake fluid. So I am looking into getting another locally cuz I found it for $127 so far. I think its like $80 by me. Gonna find out tomorrow though.
Reply #4604 on:
March 22, 2012, 03:37:10 PM »
Ah... got the ride inspected today and passed! They were very thorough there but they didn't look under the hood!
306
307
308
309
