November 05, 2026, 07:57:34 PM
263
264
265
266
Topic: What did you do to your Gen7 today? (Read 3816602 times)
Reply #3945 on:
October 06, 2011, 04:00:21 PM »
Nice!
Reply #3946 on:
October 06, 2011, 07:36:43 PM »
Adjusted the shit out of my parking brake. Seems like it wasn't touched since new. I should've known. Oh well. Problem fixed.
Reply #3947 on:
October 06, 2011, 08:48:40 PM »
drove teh car in the rain. Found out a rock chipped my fogs. SOB. lol
Reply #3948 on:
October 06, 2011, 10:35:31 PM »
Quote from: CrackerTeg on October 06, 2011, 07:36:43 PM
mine feels a little sloppy, is the adjustment screw on the cable under the car, or under the center console??? IIRC from installing my short shifter, it is under the CC, but I don't know for sure...
swapped in some LED's, the white goes really nice with the white in the gauges and stereo...seems like there should be more light though, like under the dash for the feet. the ones on the door seem kinda useless, then there is only the two from map lights, and the one dome light in the rear.
YOOOO!!!! what's up with the rear door lights?!?!?!?! or should I say, Lack there of! I removed the lenses (red, weird), and there wansnt anything there, yet there were cut-outs for them? I'd like to put clear lenses in there and an actual light. anyone done this???
the rest of the lights should be delivered tomorrow, today I only got the doors and the trunk one done, but I was able to do all but three in my jeep, which should be the same as the ones coming in tomorrow for the accord...
Reply #3949 on:
October 06, 2011, 10:38:21 PM »
Yeah, its under the CC, sucks for the 7th Gens you have to take out the whole CC. On my 5th Gen there was a little panel that popped out in the middle of the CC so you could adjust without takin the whole thing out.
Reply #3950 on:
October 06, 2011, 11:12:38 PM »
Mark, nobody has tried to install lights in the rear doors that I know of. Honestly, it's not that hard to do if you understand DC wiring. I was planning on doing it at one point, and have all the parts, but other projects have taken priority over rear door lights.
Also, there's a DIY on how to adjust the parking brake. If you take the console out, you're doing it the hard way. All you need is an extension and you're good. You can take off the rear cover of the center console and get access.
Reply #3951 on:
October 07, 2011, 05:56:40 AM »
Just got in from doing more work on my car. Yes, I realize it's 5:45 am my time. I was on a roll and just didn't stop. I wasn't planning on staying up this late, but it happened. I put on the half shaft, installed the axles, changed my oil, filled my tranny fluid, filled my coolant, put in the clutch master cylinder and slave cylinder and then bled the system, and bolted up the battery tray. At this point, all I need to do is tighten the axle nuts and drop in the battery so I can start it up.
Reply #3952 on:
October 07, 2011, 07:18:27 AM »
Wow. That's crazy tim. I miss my gen 7.
Reply #3953 on:
October 07, 2011, 11:53:39 AM »
Quote from: sherker55 on October 06, 2011, 10:35:31 PM
Clear lenses, yes. Actual lights, no.
--Dave--
NECM Squad
Profile & Mods List
2003 I4 Accord Sedan
Reply #3954 on:
October 07, 2011, 11:54:55 AM »
My GFs Grand Am had round reflectors (red) on the inside so when you opened the door it made you more visible... I guess. lol
Reply #3955 on:
October 07, 2011, 08:52:42 PM »
Drove it to Chicago today. Averaged 31 MPG on the way up. Not to bad for a v6. I've got it hidden in the city until Sunday lol.
Reply #3956 on:
October 07, 2011, 10:12:16 PM »
finished with the map and dome light LED's, looks sweet! also finished my jeeps dome/rear passengger map lights....for some reason they all stay on, even when switched off from the main light switch control on the turn signal post...why would they do that??? Im going to go out now and check again to see if they still are on!
Reply #3957 on:
October 07, 2011, 10:15:04 PM »
ok so now they are off, fucking weird, maybe they are just "burning" off extra power once everything is shut down...
Reply #3958 on:
October 08, 2011, 09:14:23 AM »
Drove it back home for another 1000 miles. Really nothing much.
Reply #3959 on:
October 08, 2011, 08:41:02 PM »
Drove it and broke it.
263
264
265
266
