November 05, 2026, 08:09:22 PM
Pages: « First < Previous 1 ... 216 217 [218] 219 220 ... 596 Next > Last »   Go Down
Author Topic: What did you do to your Gen7 today?  (Read 3816713 times)
dizzle pfffft.
« Reply #3255 on: September 14, 2010, 09:13:10 PM »
i was planning on remounting my roof spoiler today. i ended up cracking part of it in the process. ill have to sand off the paint, prep it and smooth it with bondo. then paint again.
« Reply #3256 on: September 16, 2010, 12:53:18 PM »
got my ATLP v1 j-pipe installed. Man the car is just that much funner to drive. It does sit pretty low but I am sure I am fine. My car is not even that low.
Next I am going to try the zip tie trick on my car shifter cable.
« Reply #3257 on: September 16, 2010, 12:57:03 PM »
What is the "zip tie trick"?
« Reply #3258 on: September 16, 2010, 02:50:18 PM »
I'd like to know as well.
fabulous010 pfffft.
« Reply #3259 on: September 16, 2010, 06:37:18 PM »
+1
« Reply #3260 on: September 16, 2010, 10:01:30 PM »
http://tl.acurazine.com/forums/showthread.php?t=761833
« Reply #3261 on: September 16, 2010, 10:10:46 PM »
Ummm, what?
« Reply #3262 on: September 20, 2010, 11:24:24 PM »
changed oil. Redline 5w30 + pureone filter + added a quick drain plug FTW. The oil can out blacker then night. On the car it was showing 20%.. Ewww haha
accord-greddy
accord-greddy pfffft.
« Reply #3263 on: September 22, 2010, 10:26:32 AM »
 just painting , and its good
« Reply #3264 on: September 22, 2010, 11:25:47 PM »
nos???
accord-greddy
« Reply #3265 on: September 23, 2010, 02:45:13 AM »
Yes.   Tongue
« Reply #3266 on: September 23, 2010, 10:12:33 PM »
put back my oem oil drain plug. the quick drain crap was pissing my redline all over my garage floor...
jobata23
jobata23 pfffft.
« Reply #3267 on: September 24, 2010, 08:06:18 AM »
i flushed engine coolant and about to do another transmission oil change next week.
« Reply #3268 on: September 24, 2010, 01:11:57 PM »
took out DL50 bulbs out of fx35 fogs, replaced with 85122+, 55W ballasts now powering them, checking if i can notice brightness change, color deff changed a little (DL50 are 3900k, 85122+ are 4200k), cutoff got more blue hue in it. little trunk project in mind to separate sides like Audis have so my shit doesnt roll around trunk and more organized and maybe replace shitty carpet
cleaned headlights, more clear again, i guess i have to do it once a month or so
« Reply #3269 on: September 25, 2010, 03:30:24 PM »
So over the past week ive been trying to figure out some issues i had lingering:
Found out the reason for my upper radio display blanking out, but not before cracking a section of it. I will do a write up on how i finally fixed it & post in the audio section
The oil puddle i was seeing had went away. (i suspected the rear main seal). Earlier this week, i started noticing the puddle again and went back to check if its coming from the same place. Turns out this puddle is coming from the transmission where the axle goes into the diff. Plan to take the axle out n check the seal.
Another chapter with this car....
« Last Edit: September 25, 2010, 03:34:59 PM by Rich01 » Logged
Pages: « First < Previous 1 ... 216 217 [218] 219 220 ... 596 Next > Last »   Go Up
