November 05, 2026, 06:50:01 PM
Pages: « First < Previous 1 ... 212 213 [214] 215 216 ... 596 Next > Last »   Go Down
Author Topic: What did you do to your Gen7 today?  (Read 3816485 times)
« Reply #3195 on: August 07, 2010, 11:37:12 PM »
Had a great drive and got my self some TL wheels from tim. Will be installing them soon
« Reply #3196 on: August 08, 2010, 12:04:00 AM »
Glad I could help Mike.  I got your headlights from Clemente.  Clemente, I'm glad we could work it out so you could get some new wheels.
« Reply #3197 on: August 14, 2010, 12:03:15 PM »
Yesterday i washed her and wax and sealed my wheels.
For the pass few days ive been trying to figure out my upper dash display blanking out issue. I took it apart, but didnt see a way to seperate the LED display from the circuit board (great job Honda). They are attached by about 30 pins soldered together. I checked the solder contacts on those pins and reflowed the solder. This didnt help. I was not able to get to the solder contacts on the connector that the multi-pin connector from the radio goes to. I am going to be checking the connector end that goes to the radio next.
« Reply #3198 on: August 14, 2010, 01:11:18 PM »
Drove her to Newport and placed an offer on my dream car!
Reputation Power: 18
alpha pfffft.
« Reply #3199 on: August 14, 2010, 01:12:49 PM »
which is?
« Reply #3200 on: August 14, 2010, 01:17:23 PM »
1997 Supra Turbo but, this guy wants more than I can really offer we will see what happens over the next week.
« Reply #3201 on: August 14, 2010, 01:24:02 PM »
On Thursday I replaced my Omni Power CMC with an OEM replacement, discovered that my 3rd pedal was busted, so I swapped that out with the one that was re-welded and reinforced.  I also swapped my chrome Neuspeed STB with a black Neuspeed STB.  Then I washed my engine bay and cleaned my wheels and the carbon build up from my exhaust on my rear lip.
« Reply #3202 on: August 14, 2010, 01:29:44 PM »
No more carbon build up? Thats been there since I met you! Pics or it didn't happen!
« Reply #3203 on: August 14, 2010, 02:33:08 PM »
I've cleaned it off plenty of times, but it always comes back.  Anyway, I used Surf City Road Trip Grime Destroyer.  I rinsed it off with some water first, then sprayed the Road Trip on, let it sit for about 30-60 seconds and then rinsed it off and about 90% of the carbon came right off.  I sprayed on some more Road Trip and let it sit for another 30-60 seconds, then agitated it, and rinsed it off again and that got the rest of it off.  I should also mention that I was using my Nomad portable washer, which has a lower water pressure than a normal hose does.  That stuff works great!!
Anyway, you'll see tomorrow Mike.  I'm going to detail my car tonight after work (and after I swing by that dealership for you).
« Reply #3204 on: August 14, 2010, 02:42:29 PM »
My car is a filth bucket and I don't have time to do anything about it.
Paulius005 pfffft.
« Reply #3205 on: August 14, 2010, 03:27:49 PM »
Finally finished up my audio install and my Legend GS brake upgrade and fixed my drivers side door.
Paulius San Jose, CA
« Reply #3206 on: August 14, 2010, 05:18:33 PM »
came back from cambodia. Great 2 weeks but not so great for the car. Had some kind of berry that fell all over the car. Some of it stain the paint even after I washed off the berries.
Also my battery died... So I got one from walmart 85 bucks after tax and core return. 300 more CCA and 60 more reserved then the OEM battery.
« Reply #3207 on: August 14, 2010, 11:29:35 PM »
cleaned my wheels wow wheel cleaner does wonders
« Reply #3208 on: August 14, 2010, 11:45:14 PM »
Hahaha.  Those fuckers were pretty hit when I saw them last week.  They were darker than mine, and mine are graphite.
I took the time to wash my car today.  That's about it though.
« Reply #3209 on: August 14, 2010, 11:52:32 PM »
Man i spray them down with wheel cleaner  and let it set for few mins and rinse off, i used my 12v power washer and wow they look all glossy and clean now i saw chunks of dirt just fall right off  Grin
Pages: « First < Previous 1 ... 212 213 [214] 215 216 ... 596 Next > Last »   Go Up
