August 31, 2026, 01:09:38 AM
Emergency brake buzzer
Topic: Emergency brake buzzer (Read 18987 times)
December 01, 2009, 10:17:59 AM »
Anyone know where this annoying little buzzer is? I want to remove it if it isn't the same one used for lights on. If it is tied in, which inputs would I need to remove to shut the thing off when I use my e-brake? It may sound stupid for my wanting to remove it but its an annoyance I don't care to have.
Re: Emergency brake buzzer
December 01, 2009, 10:44:30 AM »
It is built into the MICU under the dash, a easy way but you will lose indication of E-Brake, is to disconnect the switch attached to the handle under the cup holders.
December 01, 2009, 11:14:36 AM »
I knew there was something else tied to it. Fucking lame. There's gotta be another way around it to avoid losing the brake indicator in the cluster even if I have to desolder something and pull shit apart and cut myself several times in the process.
December 01, 2009, 12:13:26 PM »
Nothing I know of, the buzzer is in the MICU and is tied to the processor in it which is then tied to the CAN bus which feeds data to the cluster, to kill one , you kill both since both are signaled from the same line.
December 01, 2009, 12:41:14 PM »
Now that puts a damper on my day. Fuck.
December 01, 2009, 02:00:17 PM »
Sorry dude, maybe what you could do is wire a different light and add it to the dash to replace the e-brake warning light. Also disconnectng the ebrake switch from the MICU will NOT affect the cluster lights function as far as fluid level warning indication, just ebrake.
December 01, 2009, 02:06:08 PM »
Oh really? I thought it killed the light all together. Now I'm in a better mood. I think I might come up with the light workaround for the e-brake just so the light is still there just without the annoying beep.
December 01, 2009, 02:26:02 PM »
I don't think my coupe beeps for the e brake is it year, transmission or trim leval specific?
December 01, 2009, 02:28:32 PM »
Z, just curious, why do you want to remove the beeping function?
December 01, 2009, 02:36:14 PM »
mine has never beeped....? so I have no idea what this thread is about..?
December 01, 2009, 02:44:11 PM »
it should if the e-brake is engaged while trying to drive.
December 01, 2009, 02:46:53 PM »
DING DING DING. Dave hit it on the head. I want to remove it because its fucking annoying. Sometimes while slowing down near cops, I'd rather not let them see my brake lights otherwise it sends a nice little red flag. Slowing down with the e-brake ever so slightly doesn't do that.
December 01, 2009, 02:53:14 PM »
are you an auto?
December 01, 2009, 02:55:30 PM »
Im sure that'll screw something up Z, esp at hwy speeds. Why not splice some wires, run a switch, flip it so it turns your brake lights off, hit the brakes and no lighty lighty and your good. Not like I've done this before, but I know it works.
*edit* Yeah David, Z has a manual....why not just throw it down a gear or two, better deceleration than the e-brake!!
December 01, 2009, 03:16:16 PM »
I know what it is. I'm telling you it'd never gone off in my coupe.. I'm auto. i do exactly what Z was describing, use it to slow down slightly at night when I see a cop just in case I'm over the speed limit by a few.. but there's never been any beeping or tone.
