September 25, 2026, 04:14:50 AM
Author Topic: Re: 2 SUSPENSION PROBLEMS  (Read 9373 times)
NWINNIE34 pfffft.
« on: September 23, 2009, 12:30:03 PM »
not sure what blown motor mounts would feel like
but if i accelerate semi-hard i feel a shudder at low rpms too..... feels like the engine is moving around or working really hard in my I4
might be solved by new motor mounts (which may be coming up on a group buy soon for you V6 guys, possibly us I4 guys too) or install a stiffy kit to keep the engie from moving around....
i know this doesnt answer yur question but if it makes you feel any better i feel the same thing too
Milan pfffft.
« Reply #1 on: September 23, 2009, 04:31:33 PM »
Check your sway bar end links.  Even if they are a little loose, they will make lots of noise going over any rough pavement.
« Reply #2 on: September 23, 2009, 06:30:41 PM »
Quote from: "NWINNIE34"
The same thing happens to my car as well. I don't like how it feels, either, lol.
Reputation Power: 10
NVA-AV6 pfffft.
« Reply #3 on: September 23, 2009, 09:59:46 PM »
Get your tires re-balanced first, next time you are in my area, let me know when you can stop by and I'll take a look at your mounts.
jobata23
jobata23 pfffft.
« Reply #4 on: September 24, 2009, 07:27:44 PM »
im getting the same thing, it only happens when i pull off from a dead stop or sometimes when i turn, but not as pronounce compare to starting off line. i check everything and it looks like everything is tight except my front left camber kit is loose but tightly its bolted on the knuckle. i think is toasted due to cali roads when i drove back from oregon. anyways i decided to buy the oem balljoints again to replace my front camber kit and will be here next week.  Hopefully this solves the problem.
CYANiDE pfffft.
« Reply #5 on: September 24, 2009, 07:31:41 PM »
I feel it sometimes but on rough roads. I think the tires might be catching some of the bad road and making the car lean in different directions, but IDK.
Jobata - what kit is that on your car?
InFuMoUs
InFuMoUs pfffft.
« Reply #6 on: October 12, 2009, 06:31:59 PM »
If your mounts were bad, I dont think they would make any noise when the car is in motion. You'll probably feel it in the steering. You'll can also know if they were bad just by looking at the engine and seeing alot of vibration than the norm, but like Milan suggested check ya sway links and maybe also check ya bushions in ya lower control arms.
EliteCM Profile
NVA-AV6 pfffft.
« Reply #7 on: October 12, 2009, 10:05:26 PM »
Fill the new one with 3M window weld, it comes in a cauking like tube and can be gotten at advance auto parts stores. Fill it and let it sit for a few days before installing.
jobata23
jobata23 pfffft.
« Reply #8 on: November 12, 2009, 09:37:51 PM »
so derrick did you find the problem cuz i thought it was my ball joints and replace it with the stock, and the noise is still there.
Asim pfffft.
« Reply #9 on: November 14, 2009, 11:43:18 PM »
if its a click noise that engages and disengages when you accelerate and sometimes when you break, its actually some plastic body panel underneath the car causing it
i noticed i had it, and found a tsb about it. I didn't bother fixing it since its just an annoyance not a problem
jobata23
jobata23 pfffft.
« Reply #10 on: November 15, 2009, 02:37:22 PM »
^^ but the noise is metal to metal sound
