October 31, 2026, 10:57:23 AM
My LED projects, LED tail lights, interior lights, other
Topic: My LED projects, LED tail lights, interior lights, other (Read 38614 times)
February 07, 2009, 08:16:40 AM »
Started my custom LED tail lights
using red/orange Lumileds leds (hpwt-dh00 bin j16,j25,j22 and h34)
2 rows of leds (120 leds per side. not including backup leds and turn signals)
bottom and top row for brake and running lights
middle row 20 leds will be used as rear foglights and come on with front fogs
Turn signal will be in middle of tail where its clear section for backup lights. sorta like some bmw 5 series have red led turn signals
that will be 48 leds on each side, running at max curent(60-70ma regulated with voltage regs(sharp)
backup lights will be on same section
they will have 54leds at 2 or 3 different angles.
there will be maybe 9 or so facing to sides like turn signals
here is pics of almost completed tail light
lens off
lens on
you can see where i put 35% tint film on and it didnt change brightness of leds
as you might notice middle strip(turn signal) is "wierd", not all leds are visible from same angle, that was done on purpose so turn signal would be visible from wider angle, there are 3 sections and they are mounted at 3 different angles
this what it should look like when both sides are done
comparison. same camera settings for both pics, left is dimmest setting, right is highest setting (60mA)
more pics
http://s157.photobucket.com/albums/t55/sy272004/Projects/LED%20taillights/
backup lights (possibly some blue and red leds for strobes)
54+ 5-chip leds (there will be about 9 or 12 leds facing to the sides)
backup lights gona be insane, thats about 1000 lumens per side (running at 3.8V and 90mA, or 874 at 3.6v at 90mA, thats asuming leds are about 75 Lumens/Watt)
mounted backup leds on board with 2 versions, not sure which ill go with.
question: what should creep4 be run at? on spec sheet it says 3.6v-4.6v
this will be for backup lights only (probably for strobes as well)
i heard ppl run them at 80mA, at what Fv (3.6 or 4v)?, they will be on sharp voltage reg so i guess max is 4V per string of 3
note to myself
http://www.rimindustries.com/product-p/11.1010sf.htm
Last Edit: April 17, 2009, 03:40:09 PM by AV6NHBP6SPD
Re: My LED projects, LED tail lights, interior lights, other
February 07, 2009, 08:17:14 AM »
headlight turn signals with red/blue strobes (not finished yet)
from about 10ft away at full brightness
February 07, 2009, 08:17:50 AM »
was trying to find my all LED projects and they are all over the place so here is thread of all in one
here is more detailed threads (if you got questions for those thread then pm, i no longer watching them)
http://www.v6performance.net/forums/showthread.php?t=142466
http://www.v6performance.net/forums/showthread.php?t=142839
http://www.v6performance.net/forums/showthread.php?t=138208
http://www.v6performance.net/forums/showthread.php?t=124295
The Dome (40 White superflux leds)
Map lights (12White superflux leds in each light)
Door lights V1.0 (16 red and 8 white superflux leds)
Door lights V2.0 on the way(20 pure red Lumileds, 7 white superflux leds)
Under door lights (6 white supreflux leds)
License plate lights(Kunal has them now, 4 white leds in each light)
Heated seats (changed from orange to pure red leds)
Sunroof, TSC, Foglights (changed from orange to pure red)
February 07, 2009, 08:20:47 AM »
ok cant hold it any long and not posting it here
started 6th gen led tail light project(yes i know, my 7th gen tails are not done yet). here are results so far
parts
oem tail lights
ebay clear tail lights
lumileds(red/orange) running at 60ma i think
daves optidrives
clear lenses
comments are welcome
Last Edit: May 29, 2009, 01:01:24 PM by AV6NHBP6SPD
February 07, 2009, 06:45:04 PM »
Awesome work Misha. Those turn out great.
February 07, 2009, 10:55:30 PM »
Looks good Misha. I hope you can get those tail lights to have sequential turn signals. That would be awesome. I also love the lights in the bottom of your door panels. I need to do that to my car. I have about 40 superflux LED's that will hopefully find a home in my door panels one day. Maybe even in my overhead dome light too.
February 08, 2009, 10:15:02 AM »
not doing sequential turns as i decided. one reason is because turn signal leds are at 3 different angles so it will look wierd, but i will probably still order 4 sets of parts to make sequential controllers. it took me 3 hours yesterday just to figure out how to wire PWM and sharp regulator together, and thats with Daves schematics.
February 11, 2009, 02:27:07 PM »
Can't wait for the final stage of these tailights. As always, very admirable work Misha.
February 11, 2009, 03:45:57 PM »
How many hours of work went into these?
February 11, 2009, 04:28:37 PM »
so far about 40 hours. on one tail. couse first one always takes long time. second you just copy everything so not much R&D
February 11, 2009, 04:31:47 PM »
Wow that's some major dedication! They look very good!
February 12, 2009, 09:21:03 AM »
i might consider selling boards based on todays tests. i think they are too bright. and if thats the case then id rather use pure red leds since it will be bright enough with little different design for turn signal part
February 12, 2009, 10:52:36 AM »
Are you using a PWM to dim them?
February 12, 2009, 11:33:19 AM »
yes. combination of PWM and sharp 12V reg. pretty much same thing as Daves optidrive which i ordered yesterday since its easier to do then riging up what i did. and now that i think of it. he is using 15 step pot to controll brightness so it will be easier to use, im gona use what ihave now for tails for my front turn signals and make ptidrives for tails when they come in and i still need to order other supplies that are not included with optidrive
February 12, 2009, 06:32:11 PM »
did some testing. they are bright. with tail tint it will be perfectly bright, just dont like turn signal very much couse leds are at 3 different angles
