August 05, 2026, 07:02:39 PM
Pages: [1] 2 3 ... 7 Next > Last »   Go Down
Author Topic: Recipe Thread  (Read 105661 times)
« on: February 05, 2009, 11:58:18 AM »
As Mike requested, here's a recipe thread that anyone is more than welcome to add to.  I'll start off with a few basics that are always a crowd pleaser.
Guacamole
Ingredients
  • hass avacado (4)
  • tomato (1 medium)
  • yellow/spanish onion (1/2 medium or 1 whole small)
  • cilantro (1/2 bunch)
  • lime (1)
  • salt (to taste)
Method
  • halve the avacados, remove the pits, and scoop them out with a spoon into a bowl
  • mash the avacado with a potato masher or fork
  • dice the tomato and onion and add to the avacado
  • rinse the cilantro and finely chop, then add to the avacado mixture
  • squeeze lime juice and add salt to taste
  • enjoy!
Pico De Gallo
Ingredients
  • tomato (4-5 medium)
  • lime (1)
  • salt (to taste)
Method
  • dice the tomato and onion into a bowl
  • rinse the cilantro and finely chop, then add to the tomato mixture
  • enjoy!
« Last Edit: July 01, 2011, 10:16:36 PM by timot_one » Logged
« Reply #1 on: February 09, 2009, 08:44:07 AM »
Keep them coming.... How about the ribs! I've read about them, and ment to try them but, I've never quite gotten around to it!
« Reply #2 on: February 09, 2009, 12:51:31 PM »
I'll post that one up a little later.  This summer, I'm going to make my own smoker to do some real BBQ.
« Reply #3 on: February 09, 2009, 12:53:52 PM »
Lol you do everything over the top don't you. If your smoking meat I might have to visit.
Blackhawk pfffft.
« Reply #4 on: February 11, 2009, 08:39:49 AM »
Tim, I'm making crack dip at Skips when you come down.
« Reply #5 on: February 11, 2009, 09:48:42 AM »
Define "Crack dip"?
« Reply #6 on: February 11, 2009, 11:49:44 AM »
Quote from: "Blackhawk"
I'm gonna make my ribs while I'm down there.  Recipe will be up soon.
« Reply #7 on: February 11, 2009, 11:55:29 AM »
Define "Crack dip"?
Crack Dip defined!!
JT's Crackdip:
1 full 16oz bar of Velveeta cheese
1 Full 16oz can of Hormel Chilli (no beans) or home made seasoned ground sirloin
1 Full jar Tostitos or sam's club brand Hot salsa
1tsp Your favorite taco meat seasoning mix (only if using ground beef)
1tsp "Adobo" seasoning mix (only if using ground beef)
Cut the cheese bar up into 1" thick bars, and spread them evenly in a crock pot set to 200F. While the cheese starts to melt, open the chilli can (or cook up the ground beef with medium heat and season as you cook). Stir cheese around to make sure it is properly melted all around. You may have to spike the heat to get the cheese initially melted but quickly make sure to go back down to simmer heat once it's fully melted to avoid burning it. Dump the chilli or ground beef and salsa into the crock pot and throughly mix until all ingredients have been fully blended together. Grab your favorite tortilla chips and enjoy!!!
« Reply #8 on: February 11, 2009, 11:57:04 AM »
Szilagy’s Super Scrumptious Sensational Slurpin Somethin’ Special Rib Recipe
1 1/2 pounds spare ribs (baby back ribs are better)
1 Big Pot
Fill with hot water, Add:
3 Tablespoons Salt
1 Tablespoon Pepper
1 Onion (Cut in 1/2)
1 Carrot
1 Celery Stalk
1 Cinnamon Stick
1 Handful of Whole Cloves
Cut up ribs to serving portions. Drop in Pot. Bring to boil. Turn down heat. Let simmer or 45-55 minutes.
Remove ribs. Place in caserole dish. Cover with rib sauce and let marinate for 1-12 hours.
Place bone side up in broiling pan and broil 5 minutes. Turn over to meat side and broil another 5 minutes (‘till just starting to char). Remove from oven and place in casserole. Pour rib sauce over ribs and serve hot.
Secret Rib Sauce
1/4 Cup Brown Sugar
1/2 Cup Catsup
2 Tablespoons Cider Vinegar
1 Teaspoon Dry Mustard
1 Teaspoon Worcestershire Sauce
1 Teaspoon Prepared Horseradish
After ribs have been removed from broiling, mix 2 teaspoons corn starch with 2 tablespoons cold water and stir into sauce. Heat in sauce pan until it begins to boil and thicken. Pour over broiled ribs.
« Reply #9 on: February 11, 2009, 02:00:13 PM »
I have to cook these i've heard they are amazing!!
Blackhawk pfffft.
« Reply #10 on: February 11, 2009, 02:21:06 PM »
Thanks for transferring over Tim. I still haven't been able to access the old forum.
« Reply #11 on: February 11, 2009, 02:55:24 PM »
Only mods have access to the old forum.  It will be useful to get stuff over here since the new g7a format is ass backwards.  Let's keep it on topic and keep the recipes coming.
ibcnunv pfffft.
« Reply #12 on: February 12, 2009, 08:33:05 AM »
My Lasagna Recipe
Start with the following in a pot:
1 pound (450 g) of sweet Italian sausage
1 pound (450 g) of ground beef
1/2 cup (120 mL) of chopped onions
2 cloves of garlic chopped
The flavor of the Italian sausage varies from brand to brand. You may need to try a different brand the first couple of times you cook this dish. Find the flavor you like the best.
Brown the ground beef, Italian sausage, onions and garlic in a pot until they start to look cooked. It takes about 6 to 9 minutes to brown the meat. I like to use a Dutch oven to cook this portion of the recipe. I use a medium low temperature to brown the meat. It is optional to remove the grease from the meat once it is finished browning, your choice.
Add the following:
1 (28 ounce) (784 g) can of crushed tomatoes
2 (8 ounce) (230 g) cans of tomato sauce
2 (6 ounce) (168 g) cans of tomato paste
1/2 (120 mL) cup of water
Gently stir this into the cooking meat.
Add the following:
2 tablespoons (30 mL) white sugar
1 teaspoon (5 mL) fennel seed
2 teaspoons (10 mL) fresh Basil leaves chopped
2 tablespoons (30 mL) fresh Italian parsley chopped
1 teaspoon (5 mL) salt
1 teaspoon (5 mL) Italian Seasoning
1/2 teaspoon (2.5 mL) ground pepper
Gently stir these seasoning into the sauce.
Cover the pot and let the meat sauce simmer. Simmer on low heat for 1 hour and 30 minutes This is the ideal simmer time but not mandatory. If you don’t have time it will still be great after one hour of simmering.
I will sometimes make this sauce and refrigerate it after it finishes simmering. I will use the meat sauce the next day to put the rest of this recipe together. For some reason Italian meat sauce taste even better the next day. But that’s up to you.
Soak 12 lasagna noodles.
The lasagna noodles need to be soaked in hot tap water for 15 minutes.
While the noodles are soaking you can make the cheese filling.
Put the following in a mixing bowl:
23 ounces (644 g) of ricotta cheese.
1/2 teaspoon (2.5 mL) fresh grated nutmeg
Grate fresh nutmeg over the Ricotta cheese.
Add the following:
1 egg
Mix these ingredients together with a spoon
Now we start building the lasagna layers.
Use a 9×13 inch baking pan.
Spread 2 Cups (480 mL) of meat sauce on the bottom of the pan.
Remove your lasagna noodles out of the water bath. Shake water off wet noodles.
Lay 6 noodles across the layer of sauce.
Spread half of the ricotta cheese mixture over the layer of noodles.
Spread 1/2 of the mozzarella cheese over the ricotta layer.
Sprinkle half of the Parmesan cheese over the mozzarella layer
Spread 2 cups (480 mL) of meat sauce over the cheese layer
Lay down the next layer of noodles
Spread the remaining ricotta mixture over noodles
Spread the mozzarella and Parmesan cheeses saving some cheese for the top of the lasagna
Put the last layer of meat sauce on the cheeses
Sprinkle the remaining cheese on top.
It should look similar to the picture above.
<a href="http://s3.photobucket.com/albums/y95/ibcnunv/ECM/?action=view&current=ingredi17.jpg" target="_blank"><img src="http://i3.photobucket.com/albums/y95/ibcnunv/ECM/ingredi17.jpg" border="0" alt="Photobucket"></a>
Cover with foil
Bake in preheated oven at 350 F (177 C) for 25 minutes
Remove foil and bake uncovered for another 25 minutes.
Remove from oven and allow to cool for approximately 15 minutes.
Ingredients
1 pound of sweet Italian sausage
1 pound of ground beef
1/2 cup of chopped onions
1 (28 ounce) can of crushed tomatoes
2 (8 ounce) cans of tomato sauce
2 (6 ounce) cans of tomato paste
1/2 Cup of Water
2 tablespoons white sugar
1 teaspoon fennel seed
2 teaspoons fresh Basil leaves chopped
4 tablespoons fresh Italian parsley chopped
1 teaspoon salt
1 teaspoon Italian Seasoning
1/2 teaspoon ground pepper
23 ounces of ricotta cheese.
1/2 teaspoon fresh grated nutmeg
1 egg
1 pound shredded mozzarella cheese
1 cup grated Parmesan cheese
12 lasagna noodles
« Last Edit: February 13, 2009, 08:24:24 AM by ibcnunv » Logged
« Reply #13 on: February 12, 2009, 08:49:28 AM »
Looks like a damn good recipe Piero, but...
Brown the ground beef, Italian sausage, onions and garlic in a pot until they start to look.
I think there's a word missing.
Where's the picture?
You know I had to give you shit. ;)
« Reply #14 on: February 12, 2009, 08:51:51 AM »
Itilian food, and ribs combined don't sound good. But, I think its whats for dinner saturday night!
Pages: [1] 2 3 ... 7 Next > Last »   Go Up
