August 24, 2026, 06:44:19 PM
Scratch/Scrap from Front Left Suspension
Topic: Scratch/Scrap from Front Left Suspension (Read 5973 times)
dotLK
July 05, 2009, 02:08:38 AM »
I keep hearing a scraping/scratching sound every time a go over a big bump the freeway.
Any had these kind of issues before? Recently just installed the Neuspeed cupkit.
Could it be the brake bracket on the shock? I have it faced in word with the KONI logo pointing out words.
Thanks
InFuMoUs
Re: Scratch/Scrap from Front Left Suspension
July 05, 2009, 05:59:55 PM »
Well are there any scratch marks that you can see to determine what's causing it or where it's coming from? Do you hear it on the right side or the left side?
Steve -
Squad/
Team Crazy Creashunz
dotLK
July 05, 2009, 06:32:14 PM »
I'm hearing it on the driver side. But when I take off the wheel and and try to determine the cause can't find anything.
At first I same it was the brake bracket on the shock but i rotated it but still there. checked if it was the tire rubbing and couldn't be as i'm only running the TL base wheels.
July 05, 2009, 07:37:03 PM »
What do you mean by the "brake bracket"? In no way should any part of your brakes be touching any part of your suspension.
July 05, 2009, 08:51:21 PM »
The way it's described it sounds like a leaky shock/ strut. I'd check for any kind of fluid leak around the strut body.
dotLK
July 05, 2009, 10:17:17 PM »
Tim what I mention by the brake is the welded bracket that came with the shock on the driver side.
I'll definitely have to take the wheel out again and examine it carefully. Drove if again and thought I was rubbing a bit but that's not it.
Hopefully not a leaking strut but if that's the case I probably got one of the bad struts that was manufactured recently.
Update: just jacked up the car and didn't notice any oil spots by the shock. Will take the wheel off when I get home a do another check.
dotLK
July 06, 2009, 11:57:37 PM »
So I think I found the problem. Jacked up the car and removed the wheel and inspected the wheel well at every possible angle. Looked inside and noticed that one of the bumper clips had shavings and one had fallen off. Was kind of greasy but not sure where its from, couldn't find a source.
Is it possible for me to rubbing on TL base wheels running 245/45/17? I'm set on the lowest perch all around.
Folks with the supercup kit please help out.
Thanks
July 07, 2009, 09:47:56 PM »
I can guarantee that if you're too low on TL wheels with 245's and no modification to your fenders, you will rub.
dotLK
July 07, 2009, 11:46:38 PM »
Tim, thanks for the info. Looks like its time to roll the fenders...
