November 06, 2026, 05:18:34 PM
Author Topic: Motor/ECU Swap Key Question  (Read 36656 times)
BlK24a8
BlK24a8 pfffft.
« Reply #15 on: June 24, 2009, 02:10:06 PM »
I live in Baltimore Co. I emaile Cham a while ago I know he's a pretty busy guy, but if he could get his harness to work on my motor that would be great. I did read a thredd saying he would be willing to try it out on the a8 motor, so I sent him an email and will see what he says when he gets around to it. I to be honest did not think of that option...that will be something I will look into a little deeper. Thanks for all the suggestions guys, once I get this things going I'll be sure to post up some pics and details of how it all turns out.
Blinx, the shop just called and suggested the same thing lol
Skippy pfffft.
« Reply #16 on: June 24, 2009, 03:46:11 PM »
Here’s the post you’ve been waiting for.
The idea that your car is un-tunable is irrelevant to a motor swap.  We have a member currently involved in testing the new Hondata F-Pro system to see if it is compatible with the K24a8…whether it works or not..that’s a different story.
First let me dispel the idea that the K24a4 is the motor to go with.  A measly 5 horsepower difference exists between the two motors, and it’s relatively insignificant.  If it were a difference of 10hp or more then I’d say maybe reconsider…but we’re talking about motors that are very similar in construction and function.  Swapping a motor is usually done to get more power out of the gate…you will not get this with a K24a4.
The reason you are being driven towards this swap is because the people you are asking have too little insight into the Accord’s technical makeup.
Secondly, swapping to any other motor will not solve the ETC problem.  You need to eliminate the ETC system before any kind of motor swap in order to gain any headway.  With this having been said, I suggest a K24a2 (1st gen TSX).  You will develop more power out of the gate and you can boost it higher on top of that.  Properly tuned, a stock K24a2 should make somewhere around 220-235whp.  That’s already almost 100hp over what the stock Accord motor makes.
The TSX motor also uses ETC, but I recommend converting to a cable actuated throttle body and related hardware.  I recommend shying away from attempting to use the hondata TSX Kpro kit because they’ll laugh in your face when you ask for the harness pinouts so you can make the necessary changes to alter the harness to work with your vehicle.  Instead, convert the vehicle to non ETC, then buy one of Cham’s harnesses and a Kpro.
My suggested plan of action is such.  First, swap to a TSX 6 speed manual transmission.  I won’t go into why you should do so….everybody gets butt-hurt when I place my “go MT or go home” argument.  After you’ve done that, then purchase the necessary parts to convert your vehicle to non ETC operation.  This will include an older Accord ECU, 03-04 Accord accelerator pedal, engine harness, 03-04 Throttle body, intake manifold of your choice (Accord if you want cheap, TSX if you want a little more power out of the gate) cables, and a cruise control unit if you wish to have cruise control.  You can pick all of these items up used from a salvage car…you do not need any brand new parts.  After the car is converted for non ETC use, convert the car for use with Kpro.  You will need a Kpro, Cham’s dual ECU harness, and an RSX-S primary A/F sensor with a casper electronics conversion harness.
After the Kpro is in and you are running the car, make sure all the bugs are worked out.  After all the bugs are worked out, purchase a TSX longblock and swap away.  This will get you exactly what you want.  After the new motor is in, turbocharge and tune away.
To answer your actual question about keys, it’s not as simple as “yes or no”.  You will need to do a few things related to that particular sub-system.  You will need to have your immobilizer re-keyed when you swap over to a K24a4 ECU because your immobilizer will not be able to be deactivated.  After you swap to Kpro, you have the option of disabling the immobilizer or retaining its function, though you will need to have it reprogrammed a second time if you wish to use the immobilizer.
This entire project will run you upwards of $15,000.  I would suggest purchasing a civic or integra, gut it, and insert a fully built K24/K20 with a turbocharger the size of Paris Hilton's Vagina.  Timmy won the contest of what I should put in the underlined space, I would have chosen something like "the size of Manhattan"...either way i needed an object horrendously large and vulgar to put into that sentence..and Timmy hit the nail on the head.
03 CM55 NBP 6MT
hondaguy214
hondaguy214 pfffft.
« Reply #17 on: June 24, 2009, 06:34:40 PM »
yes the key should still work. I believe that the iginition module is what senses the key when you put it in the ignition. so if you swap motors the key will still work
NECM SQUAD#6
Skippy pfffft.
« Reply #18 on: June 24, 2009, 06:55:24 PM »
Well, you're half right..The Immobilizer senses the key when you try to start the motor.  If he swaps motors, it is true that the car will still START with the K24a8 computer...but the ECU will not run any other motor than a K24a8, so he will need some sort of an ECU swap along with the motor, at which time, he will need to have his immobilizer re-keyed by a honda dealer.
03 CM55 NBP 6MT
BlK24a8
BlK24a8 pfffft.
« Reply #19 on: June 25, 2009, 12:09:49 AM »
Skipp you never disappoint. I swear I'm almost at the point to pm you my build idea and have you review it lol. I liked the teg/civic idea lol. That is the main reason why I kick myself every day for selling my old 96 accord..damn I miss that car. Kinda miss the speed 6 too but not as much.
So in short let me make sure I'm clear on this. If I swap the motor the car will start HOWEVER and this goes w/o saying the ecu would be swapped as well and then at that point the key would have to be re-chipped so to speak? Assuming the member pioneering the a8 tune works this entire key question would go out the window because the motor could be tuned AND there would be no issues at all. Thanks for all the info and help guys.
Skippy pfffft.
« Reply #20 on: June 25, 2009, 07:48:03 AM »
The immobilizer system works on a set of reprogrammable keys and a receiver ring located directly in front of the lock cylinder.  When the key is inserted, the lock cylinder applies a small amount of voltage to the key blade which energizes the chip capsule inside the key body.  The key sends its unique passkey to the receiver ring and it is registered by the immobilizer system.  If the code is wrong, or the key is not programmed, the car will crank but will fail to start.  When you change ECU's, the passkey stored inside the ECU will be for a key different than the one you use to start your vehicle (it will be for the key used to start whatever vehicle the ECU came out of), and therefore, if you put any other ECU into your vehicle, your car will not start.  You need to have the immobilizer reprogrammed by honda (it's simple and takes less than 10 minutes) using their HDS tablet PC.  If you swap motors, you will not be able to use your stock ECU because it was designed to run with the K24a8 and not any other motor.  You will either need to swap to the ECU of the engine you are swapping in, or just run Kpro from day 1 and disable the immobilizer.
03 CM55 NBP 6MT
BliNx197 pfffft.
« Reply #21 on: June 25, 2009, 08:36:39 AM »
hmmm,.. good info, didn't know the stock ecu wouldn't run another engine at all, or do u mean without tuning?
Skippy pfffft.
« Reply #22 on: June 25, 2009, 11:23:54 AM »
There are several technical constraints that you would be under.  This will be very confusing to explain since there are so many intricate things to discuss.  It's all in my head and I've gone through the logic...if I try to explain it it will mess with your head.
Basically speaking, there's no way around the ETC system and you must swap out the ECU and engine harness in order to run a different motor.  The K24a8 uses a MAP and a MAF, which makes the engine harness pinout different than the K24a4's, therefore, the harness and ECU both need to go.  Simply swapping to a K24a4 ECU is not enough..it will not work correctly.  On top of that, the K24a8 does not feature an IACV, nor a TPS (which is present on all non-electronic throttle-bodies and absent on most ETC throttle-bodies)...that's just another reason that the harness needs to go.
The end-all-be-all of this argument is simple.  In order to swap an engine into a K24a8 equipped Accord, you need a k24a4 engine harness, computer, and all necessary parts to convert the vehicle to non-ETC operation.  Going into the possibilities of running a different motor on the K24a8 ECU is a pointless discussion because the 7.5 gen accord was ruined by all of the modifications they made to a perfectly good system.  Converting to the older technology will permit the OP to swap to any motor he wishes and utilize the ONLY known 100% compatible EMS on the market...that is..until you miraculously declare that F-Pro works with k24a8's...in which case all of what I just said may be disregarded...in fact, I'm going to PM you my phone number so you can physically get in touch with me when you attempt to hook your car up to the F-Pro EMS...I want to hear exactly what happens when you try to tune a K24a8 with an F-Pro EMS.
03 CM55 NBP 6MT
BliNx197 pfffft.
« Reply #23 on: June 25, 2009, 12:03:10 PM »
Quote from: "Skippy"
Hahah I appreciate the vote of confidence Skip:P but if in fact Fpro is a lost cause converting a kpro to run on a a8 as Tim said should be simply converting the ETC signal to the kproed ECU. Additionally you prolly wouldnt have to include an a4 engine harness you might be able to just use the sensors that are the same between the a4 and a8s and repin the a8 ECU connection on the Kpro harness. Im not familiar with Kmanager but does it have a MAF sensor option? Prolly wont matter sense its not running the engine anyways.
As for Honda messing with a perfectly good system I look at it like this. The basic Accord owner rarely tunes his car and the fact that they made a sensor switch between the two is annoying but I figure they thought it wasnt going to hurt their product to include some of their newer generation tech. I do think it presented a problem for RSX/S and 06+ Civic Si owners  because they are more frequently modified.
« Reply #24 on: June 26, 2009, 03:35:04 PM »
I've updated the thread title so it's not as vague.  I've also moved this to the appropriate forum since it's more of an ECU question than a motor question.
Going back over what you've said, it looks like your goals are to make more power while not getting ass raped by the cost of it all.  Mechanically, it's possible to bolt on a SC or a Turbo if you want to go FI, or to build the motor if you want to go NA.  Your problem is a tuning problem.  You can use a piggy back EMS, but we all know they aren't as good as using a Hondata product.  It seems like you have been given some bad advice from the shop you went to earlier, so I would actually recommend that you not go back there.  I would also recommend that you wait until Bryan and Paul figure out if their F-Pro solution is a suitable and then move forward from there.  Swapping the motor is an over complicated task and an unnecessary expense.
BlK24a8
BlK24a8 pfffft.
« Reply #25 on: June 27, 2009, 03:18:21 PM »
Your dead on in your assumption. I have thought about the build or what ever you want to call it for about a year now gaining information and what not. As far as my goals and so forth I have all that together and my AFI k-series kit came in last week so I'm set on that end. The shop I'll vouch for. I have seen some of the stuff they put out and what hey can do these guy are just sick. I was talking to the guy the other day and he said they just finished working on a new Si. He said they where thinking they might try the FI/C and see what that can do. I pm'ed Bryan and he said he would keep me up to date on the process. However would his system even work being his is franked?
« Reply #26 on: June 27, 2009, 11:16:51 PM »
I wouldn't waste time or money with the FIC if you can use either K-Pro or F-Pro.  I can guarantee that if you had two identical builds, the only difference being one was running the FIC and the other was running K-Pro/F-Pro, that the FIC would be making less power.
BliNx197 pfffft.
« Reply #27 on: June 28, 2009, 10:13:40 AM »
Blk to be honest, I really want you to try Fpro and see how that works but Ive got no idea how thatll react on an AT and like Tim said your definately gonna get more power with a Hondata product. So if you wanna try it its just a matter of how long your willing to have your car down for R&D. btw U got PM
BlK24a8
BlK24a8 pfffft.
« Reply #28 on: June 28, 2009, 12:58:34 PM »
I would like to be able to use a hondata product believe me! THe only thing I have seen that they have that MIGHT work is the dual adapter harness for the TSX. I have a few things I'm taking a look into, either way the car is going to be done for a while but since I work so close to where I live I should be able to make it happen lol.
Skippy pfffft.
« Reply #29 on: July 03, 2009, 08:04:43 AM »
It will be next to impossible to get the hondata TSX harness to work on your vehicle unless hondata does the R&D to convert it for you.  The only way you'd be able to modify it yourself is if you had the pinout for the harness and it would be a chilly day in hell before they gave that information up.  There are probably a few wires in there that don't match up, added to the fact that the K24a8 uses a MAF and the TSX does not, therefore some wires would need to be added/subtracted/swapped.  You're better off trying to contact hondata to see if R&D would be possible.  Just be warned, we have not received much more than negative comments from them.  Their customer service staff does not sound nice on the phone, and their hotline basically treats you like a retard to make sure that you've called the president of Iran before trying to call them for help.  I understand they must get a lot of dumb calls and stuff like that, but they really don't need to be as negative as they are.
I would wait to see if Paul's Flashpro endevor works out..if so, it will probably be the cleanest and most efficient solution for your application.  If you do wish to go Kpro, I have developed an independent solution that I have great confidence in.
03 CM55 NBP 6MT
