October 27, 2026, 09:04:11 AM
The Insight to the Inspires
Topic: The Insight to the Inspires (Read 60327 times)
October 04, 2008, 01:59:07 AM »
This thread will be the information on the Inspire headlights. The Inspire headlights do come in 2 variations. The 03-05 Inspire headlight came in a chrome housings while the 06-07 Inspire headlight came in a smoked/gunmetal housings. Now, 06-07 Inspire headlights did come with an auto leveler. You can utilize the auto leveler by using the FX35 auto leveler module. The Inspire headlights are a direct fit on the USDM Accord, but it does require modifications to the parking and turn signal wires. The Inspire headlight has 4 bulb outlets compared to the stock USDM Accord 3 bulb outlets.
Chrome Inspire Headlight Version
Smoked/Gunmetal Inspire Headlight Version
The Inspire headlights are a reflector based HID setup, but utilizes a projector based D2S bulb. High beams are a 9005 bulb which is the same as the USDM Accord high beam bulb. The turn signal will have to be modified. You will need to cut off the original turn signal socket, and replace it with either a 04+ TL turn signal socket or 01 Civic sedan turn signal socket. The parking light socket can be used from either the JDM City Light socket or 98-02 Accord parking light socket.
Now, the Inspire headlights has an area on the bottem where a ballast can be mounted. The Matsushita Gen 3 ballast off current Infiniti, Nissan, and Subaru STi are the ones that will be able to mount on the bottem of the headlights. You will also need the power plugs from the ballast, and a custom harness to power the HIDs. On the back of the headlight is spot to where a bulb cover should be mounted. You can either use an S2000 low beam bulb cover or a TSX/TL low beam bulb cover. Each cover will require modifications to fit.
The outcome should look like so or similiar.
Last Edit: February 05, 2014, 01:03:27 AM by timot_one
Re: The Insight to the Inspires
October 06, 2008, 08:37:45 AM »
Nice writeup Thien. This is every CM owner's dream mod and now they have all the info they need
October 13, 2008, 02:43:52 PM »
Can you include some pictures of the bottom where the ballast is supposed to mount Thien?
October 13, 2008, 08:49:43 PM »
Picture added Tim.
October 13, 2008, 09:14:18 PM »
Thanks man.
October 13, 2008, 10:23:47 PM »
No problemo.
lilmalu
February 03, 2009, 10:38:25 PM »
I'm a couple months late, but awesome writeup Thien. I have a question though. How will the beam pattern be for these Inspire headlamps.
Elite Profile
Cardomain Profile
February 03, 2009, 11:05:18 PM »
I've been meaning to post up beam pattern shots. Of course the beam flares more to the left because the headlight coming from Japan.
February 04, 2009, 03:57:35 PM »
Great right up Thien. This is a mod I dream of at the moment.
February 04, 2009, 05:10:30 PM »
That's a mod I dream about modding!! Maybe this summer.
February 15, 2009, 11:28:46 PM »
i dont suppose you could get a picture of the wiring harness that you had to get/make for this to work?
i'd love to do this mod.. but i'm too stingy just to get a retrofit.. needless to say, this is outta my price range! lol.
February 15, 2009, 11:41:41 PM »
Tim actually made my HID harness.
February 16, 2009, 01:01:03 AM »
Quote from: "b_beau_09"
There is no wiring harness. You must modify your OEM wiring harness for this to work.
February 16, 2009, 02:08:59 AM »
Man, yet another thing to put on the todo list. can i get a ballpark price for something like this?
rjp6262
February 22, 2009, 01:42:00 PM »
personally i think the smoked ones look better than all chome, atleast on a silver car. if i didn't do a retro i would have gone this route.
nice write up!
