September 30, 2026, 02:28:56 PM
Clutch and flywheel upgrades?
Topic: Clutch and flywheel upgrades? (Read 28765 times)
MTsixspeed
May 31, 2009, 08:47:22 PM »
Are there any options on the j series for an aftermarket single-mass flywheel and maybe a sprung clutch? It would be nice....
I figure Paul would know, but I'm really hoping to get a positive answer here because our drivetrain sucks.
p.s. Orifice valves suck too.
-Chris,
CM81 J30A4
Re: Clutch and flywheel upgrades?
June 01, 2009, 06:30:51 AM »
I onlt have a 50% sucess rate with Spec clutches, they glaze real easy. Then of course there is the CM kit, the CM kist is $1300, grabs extreamly well, but has two issues, 1 you need to add a 3mm spacer behind the release arm pivot point to get a good pedal, the second is the ring gear on the flywheel, it is 122 tooth and 12" diameter, ours is 123 tooth and 12.25" diameter, so I end up ginding the welds on a stock one and machining the flywheel to accept it, with out this you will get alot of starter noise and over time destroy the ring gear and starter.
June 04, 2009, 11:57:05 AM »
I don't trust spec either...Mike toasted one in 13k miles but that may have been influenced by a bad habit of his....we'll never know. I would highly recommend the CM kit because their clutches are very nice. If you can get it in full kevlar you'll probably never replace that clutch again.
03 CM55 NBP
MT
MTsixspeed
June 07, 2009, 10:04:06 PM »
Thanks, Paul and Skip. I am still in research mode right now for sure. Hopefully I can get the promotion at work I'm expecting and I'll have money to throw at this because it seems like it'll be expensive, but worth it.
-Chris,
CM81 J30A4
June 08, 2009, 07:45:06 AM »
Most definitely Chris, you'll have a lot of fun with a new clutch. The real research is in finding a compatible single-mass flywheel and a sprung hub clutch to go with it, you'll REALLY be having fun then!
03 CM55 NBP
MT
duck17
February 23, 2010, 03:23:59 PM »
i was looking into getting the ClutchMaster stage 3 clutch and i am curious to know how the install is going to be. i saw earlier in this post there are some problems with installing it. can you tell me how they are fixed?? thanks
February 23, 2010, 07:00:18 PM »
I put in a new clutch when the had to fix my gears...they had to take it all apart anyway...it was suggested to me by the service manager...little did he know that I wouldn't be spending the $600 or however much it was with/through him...got it for $200...well worth it. But after 20k, I can already feel it going...I hate it...I think it's due to the goddamn DBW system
February 23, 2010, 08:23:25 PM »
Delete the check valve in the slave cylinder......
February 23, 2010, 08:27:41 PM »
Quote from: "NVA-AV6"
you talkin to me?
February 23, 2010, 09:48:14 PM »
Yes, there is a diy over on azine....
February 23, 2010, 10:15:59 PM »
sweet thanks
Silver Bullet
November 06, 2012, 02:33:41 AM »
Bumping an old thread. Wondering if anyone else here running the clutch masters kit?
I am running the CM FX300 but at 14k miles it has started slipping.
2006 AV6 6MT
November 06, 2012, 05:34:30 AM »
Hate to say it, but that seems to be about normal for those very expensive kits........
Silver Bullet
November 06, 2012, 01:06:45 PM »
I heard of people with 20-30k on those and still going. I'm a conservative driver and I only drive hard maybe once or twice a week if at all.
Do your customers that run J33 and up use stock clutch?
2006 AV6 6MT
November 06, 2012, 01:21:12 PM »
What I have been using is the P2R disc with a new factory pressure plate.
