September 28, 2026, 07:20:08 PM
Author Topic: Rear Brake upgrade for ppl with GS calipers in front  (Read 31837 times)
« on: May 25, 2009, 01:53:56 PM »
so i know some ppl upgraded front brakes to GS calipers so thsi would through rear brake bias off balance and couse nose dive, so is there anything can be done. im sure there is i just didnt search yet but i think i seen it.
maybe just brakets and bigger rotors for OEM set up without spending a lot on aftermarket bbk set up
i seen that fast brake kit has it but i need something with regular solid brake rotors, no i dont want sloted or dimpled
ok Intrerest list for ppl who want to get Brackets and get rotors themself. if we get at least 5 orders then we can get it for $120 from Paul, plus shipping im sure, Paul correct me if there is mistake. ill ask on v6p as well
1. Me  (paid)
2. Jiraiya_13 (v6p) (paid
3. ADI
4. Mike bluek24a4 (v6p)(paid
5. evo6011
im sure some ppl from v6p would be interested
« Last Edit: June 22, 2009, 10:05:05 AM by AV6NHBP6SPD » Logged
Reputation Power: 10
NVA-AV6 pfffft.
« Reply #1 on: May 25, 2009, 07:46:05 PM »
There are a couple of rear upgrade kits out there, pretty much all of them are relo brackets for the OE caliper with 12.2" Honda Pilot Rotors.......
« Reply #2 on: May 25, 2009, 08:06:36 PM »
oh so thats where rotors are from. thanks Paul
is it possible for you to make brakets for this thing
« Reply #3 on: May 26, 2009, 12:11:03 AM »
Hmmmm.  I'd take one too if it were possible to fabricate the brackets.  I just need to do a rear drum to disc swap first.
NVA-AV6 pfffft.
« Reply #4 on: May 26, 2009, 05:55:01 AM »
I believe the kits with rotors are only $250 from both fast brakes and revolution brake, so I really couldn't do it any cheaper.
« Reply #5 on: May 26, 2009, 06:25:42 AM »
Quote from: "NVA-AV6"
well i cant buy those couse rotors are not solid oem kind. so let us know if you can do brakets and we can find rotors.
im sure more ppl will be intrested Paul if you can do them
NVA-AV6 pfffft.
« Reply #6 on: May 26, 2009, 07:41:25 AM »
Sure I can do the brackets and I have seen slot/drill rotors for the pilot of Fleabay. If we can get enough people together I am sure I can knock out a group of brackets with the hardware, I already have the fastbrakes kit on my car that I installed 2 years ago before I got my milling machine.
« Reply #7 on: May 26, 2009, 08:04:55 AM »
sounds good. should i or you start new thread about possible """"group buy"""" for this brakets.
i will have to get OEM blank rotors(i seen brembo for $76 each on tirerack
maybe some ppl on v6p will want some too but its up to you. im sure if you make it, ppl will grab those like candy
http://www.v6performance.net/forums/sho ... p?t=185492
NVA-AV6 pfffft.
« Reply #8 on: May 26, 2009, 08:19:44 AM »
Pilot rotors (equivelant to what ships with the kits) can be gotten from Advance for $32 ea.
« Reply #9 on: May 26, 2009, 08:57:32 AM »
yeah, just wanted same set up all around the car since ihave brembos in front with ebc and ebc in back that i just put on so hope i can do swap soon so i dont have to get new pads again
any ideas on price of this brakets if you will make them
Fenix pfffft.
« Reply #10 on: May 26, 2009, 09:17:59 AM »
Ive been doing a little research on prices of brembo blank rotors. the cheapest i found was 45 each.
Front - http://www.importrp.com/product.php?pro ... =38&page=1
Rear - http://www.importrp.com/product.php?pro ... =38&page=1
just my 2cents
« Reply #11 on: May 26, 2009, 09:56:25 AM »
^^^if that price is good. id deff get those
NVA-AV6 pfffft.
« Reply #12 on: May 26, 2009, 09:56:44 AM »
Quote from: "AV6NHBP6SPD"
Probably somewhere betwenn $125-$150 a set with the correct hradware, but to really make this feasable for me time wise I really need to run like 5 sets at a time due to machine setup time per machining operation.
« Reply #13 on: May 26, 2009, 10:39:31 AM »
sounds good to me. even though its about same price as for fast brakes but at least i can pick my own rotors
NVA-AV6 pfffft.
« Reply #14 on: May 26, 2009, 11:33:20 AM »
Maybe I will see if Excellerate can pull together something for us on new rotors and pads.....
