September 26, 2026, 03:20:41 PM
Wheels & Tires
TL wheels
Topic: TL wheels (Read 19229 times)
Re: TL wheels
Reply #30 on:
June 13, 2009, 01:45:42 AM »
Hmm, it sure does. Mike, you are on a very thin line there my friend.
Re: TL wheels
Reply #31 on:
June 17, 2009, 09:42:09 AM »
Who is THLEN?
Re: TL wheels
Reply #32 on:
June 24, 2009, 07:40:22 PM »
I capitolized the I to put enphasis* on the factthat i spelled his name right and i love a 245 tire. Fenders will more than likely be rolled using the 2nd paycheck of next month
Re: TL wheels
Reply #33 on:
June 25, 2009, 10:34:06 AM »
You can use a 245 tire but a 40 sidewall would be closer to stock diameter I believe (at least for my sedan)
Re: TL wheels
Reply #34 on:
June 25, 2009, 04:13:05 PM »
Quote from: "Asim"
I don't recommend a 245/40 size tire...your overall diameter will be off by 1 inch. Go with a 235/45 or 245/45 tire.
Re: TL wheels
Reply #35 on:
June 25, 2009, 10:40:31 PM »
Depends if its an 17 or 18. If its a 17, then yes it will be off on your overall diameter. The 18 will be close to the overall diameter.
235/40 R17 = OD: 24.4
245/40 R17 = OD: 24.7
235/45 R17 = OD: 25.4
245/45 R17 = OD: 25.7
235/45 R18 = OD: 26.3
245/45 R18 = OD: 26.7
245/40 R18 = OD: 25.7
235/40 R18 = OD: 25.4
205/65 R15 = OD: 25.5 (Accord LX)
205/60 R16 = OD: 25.7 (Accord EX, EX V6 Automatic)
215/50 R17 = OD: 25.5 (Accord V6 6-speed)
As you can see by the OD chart. The 245/40 R18 is a better choice then the 235/45 or 245/45 R18.
Tire Lesson 101 Courtesy of Thien
Re: TL wheels
Reply #36 on:
June 25, 2009, 11:32:48 PM »
Quote from: "MyNameIsThien"
You are right about a 18" wheel. I thought he was talking about a 17" wheel....hence the title of this thread "TL Wheels"
