October 25, 2026, 01:35:40 PM
Need build idea for my k24a4
Topic: Need build idea for my k24a4 (Read 52198 times)
wai_pang2
Re: Need build idea for my k24a4
Reply #60 on:
May 19, 2009, 12:18:14 PM »
Quote from: "thisaznboi88"
And basically why I want to get it done by within a budget is basically the whole point of a k24/20 frank is a poor man k24a2.
You're so wrong with that one man. I'm not sure where you got the idea that a K24/K20A2 is a poor mans K24A2. A K24A2 long block is going to be less expensive than building a frankenstien motor. You forget the cost of new/different pistons and rods, head studs, gaskets, oil pump, chain guides, having the block machined, and so on and so on. All that little shit adds up.
From what I know, the K24A2 is a good upgrade for a simple swap that will give you a bit more reliable power. A K24/K20A2 frankenstien is if you're building a race motor. That's why guys like Cham are making 500+ hp on a build like that.
That's exactly what I was thinking. Doesn't Cham have 2 TSX's long blocks sitting pretty.
Reply #61 on:
May 19, 2009, 01:20:10 PM »
I'm sure he can find one if he doesn't have some already. I'm not sure what he has at his place in Oregon, but the last time I was at his place out here he didn't have any.
wai_pang2
Reply #62 on:
May 19, 2009, 01:36:54 PM »
I was refering to the motors he has in the for sale section unless they are sold.
Reply #63 on:
May 19, 2009, 04:19:08 PM »
Considering the age of the thread, they probably are sold by now. You never know though.
Reply #64 on:
May 20, 2009, 10:09:58 AM »
Both sedans. I have steely,CAI and TSX. He has 18 rims, SR headers and exhust and pulley. both cars are well kept. All car had nothing in the trunk, He is an DX i am LX
In addition to driver error it could be 4 other things. 1. The fact that you have steelies and hes running 18s could be causing a problem with his stock suspension, harsher ride causing slower acceleration and/or the fact that they are heavier than your steelies. 2. If his engine is older he could be losing compression have them do a compression test on both of your engines if you really wanna figure this out. 3. TSX intake Mani is a huuuuuge difference in the k24s mid range power, I installed mine and it was a night and day difference, and 4. The fact that hes got headers, exhaust and a stock intake could have slightly reduced his back pressure.
Reply #65 on:
November 21, 2010, 03:40:16 PM »
I say make it stick. And then mod from there. It will be way faster than putting all f that other stuff into an automatic.
Reply #66 on:
November 21, 2010, 09:10:55 PM »
Woah. Major thread revival. He actually got rid of the car and got a V6 6MT in it's place.
