November 06, 2026, 05:28:50 PM
Author Topic: vAFC and VAFCii  (Read 25324 times)
Skippy pfffft.
« Reply #15 on: April 20, 2009, 08:43:29 PM »
Kpro is the right way to do it but you could probably skimp by using an FIC...the results won't be as awesome though....unfortunately hondata holds a monopoly in the market....I can't speak negatively of them though....I used to own one of their ECU's and they're incredible pieces of equipment.  I'll buy another one when the economy gets better so I can build my freaking engine already!
03 CM55 NBP 6MT
« Reply #16 on: April 20, 2009, 08:54:49 PM »
I totally agree with you kpro is FTW but the price tag is FTL.. like about 1500 for kpro + harness to make it work for 20hp/20tq is good but for just bolt ons and not headswap or F/I plan down the line it is kinda useless.
Also I live in CA and that check engine light always on is going to be a really pain in the ass when I need to get it smogged.
P.S TY Tim and Skip for the info
« Reply #17 on: April 20, 2009, 11:15:59 PM »
Cham has worked out a way around the CEL, which involves modifying your gauge cluster.  I'll try to post pics when we do mine.
« Reply #18 on: April 20, 2009, 11:46:57 PM »
alright thanks tim. Lets see if I can get the civic si or rsx ecu for cheap. Last time I saw it on ebay for 10 + shipping and I didn't wake up early enough it buy it...
I'll guess i should save up still and just see what you guys are doing. And it is great that the CEL got fix. that is an auto fail for smog. and I agree I should just do it right the first time but I am still not sure what I want to do and the auto tranny is no help unless someone release a tq converter for it.
Skippy pfffft.
« Reply #19 on: April 21, 2009, 08:49:40 AM »
Level-10 has been modifying transmissions for a while and all of their work is custom.  Their services are expensive but worth it if you're serious about modifying an Automatic Transmission.  For the money you may pay with level 10 you may be able to get a TSX tranny swapped in, that will definitely improve performance.
03 CM55 NBP 6MT
« Reply #20 on: April 21, 2009, 09:32:29 AM »
Quote from: "Theskip"
From expirence at least with the V6's, level 10 is not all that expensive when compared to having the stock transmission repaired. A new transmission from honda is almost = in cost to one from level ten in a J30 aplication i'm not sure about the K series transmission pricing.
« Reply #21 on: April 21, 2009, 11:28:00 AM »
Alright that kool. My main goal was to S/C with a kraftwerk but i know the tranny going to be a problem. I was wondering what is the difference between the 1000 one and the bullet proof one *3000*. I am not that familiar with tranny upgrades.
Skippy pfffft.
« Reply #22 on: April 21, 2009, 11:46:07 AM »
The $1000 kit replaces all the seals, clutches, gaskets, and rings for the auto transmission.  It's basically a tranny rebuild kit with better parts.  The $3000 kit includes the $1000 kit plus an upgraded valve body, lockup valve, and super solenoid.  It does not include the performance torque converter though, which is another $1000.  In short, these guys will rebuild anything on 4 wheels with custom parts.  For what you're going to pay with level 10, it will probably be on the level of swapping to a TSX tranny, which I would suggest in lieu of performing AT mods.
03 CM55 NBP 6MT
« Reply #23 on: April 21, 2009, 01:01:06 PM »
I am going to start a new trend now. keep high jacking his trend lol
Yeah.. Way costly. like I said before I really don't want to drop 6k into my car. I would love to swap to Mt but damn 3k... LoL I think I'll just do Cams and all bolt on with a tunes and be done with it. I need to ask cham how much is it to kpro when I provide the ecu. I am trying to get a EP3 ecu or a base rsx.
So basically here is my build idea
BC stage 2 cams =500
BC springs 250  OR  BC dual spring =325
BC TI retainers =200
kpro + harness 1350 OR AEM FIC + harness =500
Tuning 185/hr guessing 3hr tops to tune everything = 555
Labor for putting Cambs 100/hr maybe 6hr? =600
this is like maybe... 180-200whp with all bolt on
Labor and tuning is a killer...
So about 2200~3000 at most
man head swap looking good right now..
RSX or TSX head 600~700
TSX piston with rods and rings 200
rsx-s oil pump 150
timing chain 100
head gasket 120
kpro + harness 1350
labor to put it all in ?? 1500 bucks?
Tuning 185/hr umm 5hrs? 925
this is make 250whp for sure will all bolt on
~5000 maybe Labor and tuning is a killer here also...
 I am also missing other stuff like injectors, wide band o2 and some other stuff, am can't recall from the top of my head. Anyways I'll see how much I can make this summer and go from there.
Skip how much are you spending for your build?
« Reply #24 on: April 21, 2009, 03:36:53 PM »
Thread, not trend
Cams, not cambs
You're better off taking the time to do it right the first time instead of half assing it and then finding yourself wanting more.  If you're not doing the labor yourself, it's just going to cost you more in the end.  With my build, I'm only planning on having the shop tune it, but I will probably be doing the install myself to save money.  I'd also tack on another $500-800 for injectors and wideband O2 sensor and all the other miscellaneous stuff you didn't think of.  Most people just think there are the big things, but always forget all the other little stuff that you need to get when you're building a motor like this.  It all adds up one way or another.
Pages: « First 1 [2]   Go Up
