September 27, 2026, 09:40:39 AM
Bolt Ons
The Only Exhaust Thread You Should Ever Post In
Topic: The Only Exhaust Thread You Should Ever Post In (Read 200736 times)
suleman_manji
Re: Resonator Dilema
March 26, 2009, 11:58:28 AM »
Hmm, I was thinking that also but wouldn't the amount of composition materiel affect the sound?
T
X
Squad #
flick
r
fb
[img]http:
March 26, 2009, 12:27:02 PM »
Obviously, a larger resonator with equal internal properties will be quieter than a smaller resonator. Using quick and dirty math, the oval resonator has a volume of about 300 ci, while the round resonator has a volume of about 250 ci. Also, the oval resonator is labled as an "Ultra Quiet" resonator, while the round one is just a "Bottle Style" resonator. That should clue you into a little more about their sound characteristics.
Knocturnal84
Re: Huston's Exhaust Build
March 31, 2009, 11:30:36 AM »
hey does your car throw codes when you swapped out the oem cat for that one
whats the part number for the maggi high flow cat you used
Sean Artsen
BrianCrower K24
March 31, 2009, 11:48:38 AM »
ive got the same setup minus the hi flo cat. If anyone is on the fence about doing this i highly recomend it. I want to do the dual setup.
April 12, 2009, 10:57:46 AM »
Quote from: "Knocturnal84"
Same question
April 12, 2009, 11:51:19 AM »
No codes when he did the swap.
April 12, 2009, 01:52:13 PM »
Do you have a part number by any chance? Or do the codes appear later on for some reason?
mnkyman
April 12, 2009, 05:01:50 PM »
Nice install! I'm betting it sounds just as good as it looks. Using the cement blocks there for extra security incase a jack failed?
Sam
-|- 2006 I4 Sedan SE
Reply #23 on:
April 12, 2009, 05:57:19 PM »
Quote from: "Paulius005"
I believe the Magnaflow part number is
27405
. It's listed as an 05-07 part, but there's no reason why it won't fit an 03-04. I don't really understand your second question though. There were no codes after we did the swap (and replaced his bad secondary O2 sensor) that I know of. I believe everything has been just fine since the install.
Quote from: "mnkyman"
It sounds awesome. Definitely a good upgrade. You are correct about the cinder blocks Sam. We used jack stands at all 4 jack points, the cinder blocks at the front wheels, and had a floor jack at the rear. You can never be too safe.
mnkyman
Reply #24 on:
April 12, 2009, 06:41:27 PM »
27405
yup! at first i saw the blocks and was like WTF ARE THEY DOING!!! lol, then i noticed the jacks
Sam
Reply #25 on:
April 12, 2009, 07:19:15 PM »
27405
Hmm that is an expensive site you got there... in Google shopping there is a bunch around 140... Thanks a bunch for the part number though... and my second question was simply that if you put the cat on there will the codes appear later, because i remember Skippy mentioning somewhere that people always end up throwing codes... But it's good to know that this one does not
Reply #26 on:
April 12, 2009, 08:11:58 PM »
That site has high prices because it's the manufacturer's site, so MSRP is listed. That's the actual Magnaflow product page. As far as the CEL, you will be fine with this cat. I have a 5400 series universal cat and I threw codes when I installed it. That was resolved with $5.00 in parts.
Knocturnal84
Reply #27 on:
April 15, 2009, 10:00:54 PM »
i put the defoulers on before i started the car and never threw a code .... i also have the 5400 series universal cat...2.25 in/out
Sean Artsen
BrianCrower K24
Reply #28 on:
May 01, 2009, 10:49:55 PM »
With my new hi-flo cat the only thing left is the remaining exhaust. I like the quietness of the stock exhaust but would not mind a little more sound. I really like how the newer si's sound. I'm thinking about trying to put an 06 si exhaust on my coupe from the cat back. What do you guys think? Most aftermarket exhausts I hear are way to "weed-wacker" sounding or loud.
Re: 06 Si Exhaust
Reply #29 on:
May 01, 2009, 11:35:28 PM »
You can try it if you want. You may want to consider a TSX exhaust too.
