November 10, 2026, 03:07:32 PM
Author Topic: My custom box  (Read 52880 times)
« Reply #15 on: June 09, 2014, 05:55:28 AM »
Stay on topic peeps.
« Reply #16 on: June 09, 2014, 07:48:30 AM »
Its my topic so its cool with me.
Denny, its always been New Orleans. I was just trying to find work so I wouldn't have to go to New Orleans.
« Reply #17 on: June 09, 2014, 09:14:58 AM »
I'm going to NOLA next May for work. I'll help you measure the volume of your enclosure.
« Reply #18 on: June 09, 2014, 03:11:10 PM »
But that means unvelcroing(sp) it from the trunk, unscrewing the sub and pulling out the polyfill.  Cry
« Reply #19 on: June 09, 2014, 05:17:15 PM »
Polyfill isn't doing a damn thing for ya since it's a fiberglass box bud. Wouldn't you like to know that your enclosure is the correct size for your sub? If it's too large or small, you can actually damage the woofer.
« Reply #20 on: June 09, 2014, 10:55:38 PM »
He don't care. He's all about looks over function.
striktlyaccord pfffft.
« Reply #21 on: June 09, 2014, 11:09:05 PM »
Yeah. Transferring to New Orleans. Where have you been?
Not round here much apparently.  Fuck moving.  And I'll do my best to get to Rich's so we can brohug.
« Reply #22 on: June 09, 2014, 11:42:36 PM »
Make it happen brolo.
Ah well, I thought the polyfill would've helped. As for the size of the enclosure, now you got me a bit worried.
Nelson, STFU.
« Reply #23 on: June 10, 2014, 02:25:29 PM »
You should be worried. Just because it's an enclosure, it doesn't mean that it's good for your sub. Drivers have different suspension systems (stuff or loose) for the type of enclosure they're designed for. If the enclosure it too large or small, it will affect how the driver moves. Ultimately, you will have lateral movement in the voice coil, which results in heat and ultimately failure.
Look up the Thiele Small parameters of your sub and measure your enclosure, taking into account that your enclosure needs to be 80% of the recommended volume because it's made out of fiberglass. If you're lucky, the enclosure will be too big and you'll only need to take up extra space. It's super easy to fix that problem. Just text me and I'll tell you how.
If the enclosure is too small, you're kinda fucked and I would recommend starting over.
« Reply #24 on: June 10, 2014, 03:35:07 PM »
What I just found for it:
Minimum Sealed Box Volume 0.66 cubic feet
Maximum Sealed Box Volume 1.00 cubic feet
« Reply #25 on: June 10, 2014, 10:57:06 PM »
So, then your range would be 0.528-0.80 cubic feet.
« Reply #26 on: June 11, 2014, 09:00:38 AM »
I suspect I have slightly more volume than that currently.
« Reply #27 on: June 11, 2014, 09:27:11 AM »
That's a good problem then.
« Reply #28 on: June 11, 2014, 11:01:04 AM »
Indeed. A buddy also happened to have a sheet of MDF from an old project. Free fix in my future.
« Reply #29 on: June 11, 2014, 11:40:43 AM »
Just tools, time and experience required for that one.
