September 23, 2026, 03:05:36 PM
Pages: « First < Previous 1 ... 24 25 [26] 27 Last »   Go Down
Author Topic: The cigar shop  (Read 360527 times)
« Reply #375 on: October 14, 2014, 01:15:28 PM »
Have you calibrated the hygrometer? And what are u using for humidity?
« Reply #376 on: October 15, 2014, 12:18:38 AM »
Analog hygrometers are garbage. They are completely inaccurate and are really only good for decoration. Get a digital hygrometer and calibrate it before you start guessing the humidity with that analog one.
« Reply #377 on: October 15, 2014, 09:32:14 AM »
A good xikar can be had for around 17 bucks on ebay.
« Reply #378 on: October 15, 2014, 07:47:00 PM »
I'll look into that. I'm using these packet things for humidity.
« Reply #379 on: October 15, 2014, 09:14:11 PM »
Stoked, Friday after work, I'm going to a shop in east nasty to get more warped cigars!
« Reply #380 on: October 16, 2014, 08:10:31 AM »
Mike. We need to talk...
« Reply #381 on: October 16, 2014, 01:24:23 PM »
Lol this blows! I really want to pick some up tomorrow, but my check was short due to our shitty time entry system. Oh well, guess I'll pull from savings to buy cigars
« Reply #382 on: October 17, 2014, 01:17:48 AM »
You gonna have to give me a call tomorrow. Trust me, you'll want to.
« Reply #383 on: October 17, 2014, 08:36:42 AM »
Haha I'll call you when I start work
« Reply #384 on: October 19, 2014, 06:35:48 PM »
I ordered a digital hygrometer today and some gel stuff
« Reply #385 on: October 19, 2014, 08:32:48 PM »
Gel stuff isn't that great. It's only a 1 way hydration system. I would suggest Boveda packs or Heartfelt beads. Those are 2 way and will regulate humidity much better.
« Reply #386 on: October 19, 2014, 09:08:38 PM »
http://www.amazon.com/gp/aw/d/B004QCAGM0/ref=redir_mdp_mobile?ref_=pe_385040_30332200_TE_item
That's the stuff I ordered.
« Reply #387 on: October 19, 2014, 10:38:58 PM »
Yeah.  I know what you mean by the gel stuff.  It's not as good.
The two way humidification systems (Boveda packs and Heartfelt beads) will not only add humidification if the Rh is too low, but they will also draw in the excess moisture if the Rh is too high.  The gel stuff only releases moisture, it doesn't regulate the Rh.
« Reply #388 on: October 19, 2014, 10:43:47 PM »
I'll look into that
Thanks Tim
« Reply #389 on: October 19, 2014, 10:52:07 PM »
IMO, Boveda packs are the easiest solution. They're simple, replaceable, require no maintenance and last for months. I use them in my travel humidors all the time.
Pages: « First < Previous 1 ... 24 25 [26] 27 Last »   Go Up
