November 09, 2026, 07:17:06 PM
Wheels & Tires
**Wheel Recommendations/Consideration Thread**
18
19
20
Topic: **Wheel Recommendations/Consideration Thread** (Read 228291 times)
Paul3128
Re: **Wheel Recommendations/Consideration Thread**
Reply #270 on:
May 09, 2013, 07:59:07 AM »
I went with 18x8 45mm offset Enkei Tenjin. Tires are 225/45R18 Continental ExtremeContact DW. I could have gone with a 235/45R18, but I want the extra 7mm of sidewall for the crappy New England roads. I have a Neuspeed SuperCup kit with race springs, which is 2.25f 1.75r. I only slightly rub on big dips.
I used this for comparing offsets and tire diameters.
http://www.rimsntires.com/specs.jsp
I'm a man, but I can change, if I have to, I guess...
Reply #271 on:
May 09, 2013, 11:55:54 AM »
I am now wondering whether I should switch my tires for another brand or type to get better fuel economy.
I am getting about 20MPG from the current tires (nearly 12 L/100km) whereas I was getting 25MPG (9.5 L/100km) with my winter tires, and previous Summer tires if I recall. City mileage, 4 cylinder. Pretty bad imo
These RE760 tires are narrower but 27lb whereas my old tires were 24lb I believe.
Thinking about Continental DWS or Hankook V12
Reply #272 on:
May 09, 2013, 01:16:55 PM »
^^ Damn, 20 MPG for a i4 doesn't seem good at all. I average 29-31 with a heavy foot. I did have about 25-26 MPG when I had a square 19x10 with 265/30/19 tires setup. They weighed a ton, literally.
Reply #273 on:
May 09, 2013, 01:47:04 PM »
Quote from: HEcreated487 on May 09, 2013, 01:16:55 PM
Was it a metric ton, a fuck ton or a shit ton?
Reply #274 on:
May 09, 2013, 03:52:20 PM »
Quote from: CrackerTeg on May 09, 2013, 01:47:04 PM
A ton of shit, definitely. Paired well with the POS DD.
Re: Re: **Wheel Recommendations/Consideration Thread**
Reply #275 on:
May 09, 2013, 05:02:58 PM »
Lol. Nice.
Reply #276 on:
May 09, 2013, 10:38:35 PM »
Exactly man! My wheels are so light, but comon this is ridiculous. My baseline mileage is worse though must need some maintenance. But a instant 25% drop is significant and because of the tires. Also noticing handling isn't great
Reply #277 on:
August 17, 2014, 04:23:14 PM »
This seems to be the most appropriate thread to ask this.
So as some of you know, I got a set of Work Emotion CR Kai 17" wheels in a staggered setup (from a kid with a supra). Exact setup is 17x8 235/45 in front & 17x9 255/40 in the rear. I was expecting some understeer from the setup, but it seems to have gotten worst, maybe it's all in my head, so I put back my old setup back on. The options i'm looking at now are:
1)Buying 235/45 tires on the rear and spacers up front to get the offsets the same
2)Buying a pair of rims, either for the front or the back and making it all the same with matching tires
3)Just sell them and get a set of the Drag replicas in size 18. I know this is frowned upon, but i've been running Drag wheels for the last 6+ yrs.
Thoughts or other options I should consider?
Last Edit: August 17, 2014, 04:25:44 PM by Rich01
Reply #278 on:
August 17, 2014, 05:57:57 PM »
Could buy another staggered set up and sell the extra set. Buying 2 Work wheels will be expensive.
Reply #279 on:
August 17, 2014, 07:11:04 PM »
Put them on the right way with the wider wheels up front.
Reply #280 on:
August 17, 2014, 08:09:54 PM »
Quote from: Mike on August 17, 2014, 05:57:57 PM
Another staggered setup is worth the consideration if i come across one, tho it's like looking for a needle in a box of needles.
Your right, 2 wheels is like buying another set of cheaper wheels. Maybe even with tires.
Quote from: timot_one on August 17, 2014, 07:11:04 PM
I'm gonna try it. I just remember cornering sucked the last time i ran my old setup without spacers in the rear and just the ones up front.
pbplayer257
Reply #281 on:
December 11, 2014, 06:06:26 PM »
So ive been searching for an answer to a question i had, but have yet to find one. My stock tire size is 205/60/16. If i upgrade to 17" acura tl wheels with a tire size of 235/55/17, I will have a little bit of a speedometer error. Will this affect the odometer as well? Or should i just put on a tire size of 235/50/17? Will the extra sidewall affect ride quality that much?
Reply #282 on:
December 11, 2014, 06:16:28 PM »
Best thing to do is to compare tire diameters and find a set of tires that are the same diameter as your 205/60/16's for your TL wheels.
Running different size tires will affect your speedometer and it will also affect your odometer.
Pascal
Reply #283 on:
December 11, 2014, 06:21:41 PM »
Yes the tire size will affect the speed and odometer,
the correct size to have the same diameter as oem would be 245/45R17
Pascal
Reply #284 on:
December 11, 2014, 06:24:33 PM »
http://tire-size-conversion.com/tire-size-calculator/
There are many calculators online for this
18
19
20
