October 24, 2026, 08:26:31 PM
altenator problems maybe?
Topic: altenator problems maybe? (Read 23886 times)
Re: altenator problems maybe?
January 04, 2012, 06:24:12 AM »
You will see over 14V when the battery is charging.......
status
GOMD
January 04, 2012, 12:57:54 PM »
checked battery not running 12.3 something, turned on it was 14.43 which is good news. so i think the problem lies in the ignition, with my radio flashing on and off, slowly drained the batt. thanks for the help guys.
-Alec
status
GOMD
January 04, 2012, 04:22:09 PM »
so when i have heat on blast and the fans kick in it drops to 13.26 for about 1 sec. then back to 14.43.
i also read that switching your keymay help stop my radio problem with the ignititon.
-Alec
Re: Re: altenator problems maybe?
January 04, 2012, 05:46:40 PM »
Check your ground connections have u upgraded the big 3 yet as well?
Sent from my HTC Amaze 4G using Tapatalk
January 04, 2012, 05:50:59 PM »
big 3?
January 04, 2012, 06:15:12 PM »
Quote from: gargantula99 on January 04, 2012, 05:50:59 PM
big 3?
http://elitecm.net/forums/index.php?topic=730.0
status
GOMD
January 04, 2012, 06:28:34 PM »
havent even heard of it. not gonna lie looks like it be over my head if i tried.
-Alec
January 04, 2012, 06:32:50 PM »
Not as hard as it looks i learnd to do my big 3 upgrade from here
Reply #23 on:
January 04, 2012, 08:06:48 PM »
Quote from: cna on January 04, 2012, 05:46:40 PM
An open ground would not cause this problem. The big 3 upgrade wouldn't make a difference either. It sounds like there's something draining the battery when the car is off, or it's a battery that is not holding a charge any more.
Quote from: status on January 04, 2012, 12:57:54 PM
I'm having trouble following your train of thought here. How is the ignition switch causing a problem with your radio, and what would using a different key do to fix it? Is it a factory radio or aftermarket?
Quote from: status on January 04, 2012, 04:22:09 PM
That's normal.
status
GOMD
Reply #24 on:
January 04, 2012, 11:49:21 PM »
Radio is factory.reason why I think its the ignition is its like it doesn't come out of the auxiliary setting. With you key first turn only does radio and window second does the same plus air. So when Iturn the car off 30 seconds later radio would either flash off and on or just steadily be on. As if the key never went to off all the way.
Another reason it may act up is the only after market thing installed radio wise other than speakers is a sub. Some one said the way its wired from battery to the radio could be faulty. But I got it installed 2008. Didn't have this problem til late 2010.
-Alec
Reply #25 on:
January 04, 2012, 11:58:54 PM »
Could be your key switch or a hack job sub install.
Reply #26 on:
January 05, 2012, 06:30:39 AM »
I vote for the latter.
status
GOMD
Reply #27 on:
January 05, 2012, 12:43:29 PM »
ok. so i know they have a cable from the battery going towards the radio,any idea where it would plug in. im ok with taking the sub out. or did fuse wires together?
also so far since switching keys ive turned the car on 10 times and this morning the clock still isnt on. which is good. usually it would be by now.
-Alec
Reply #28 on:
January 05, 2012, 02:26:17 PM »
Cable from the battery to the radio? That doesn't make any sense at all.
Reply #29 on:
January 05, 2012, 02:33:44 PM »
Take it to a shop. Too much guess work going on.
