February 01, 2026, 04:25:53 PM
What should I do?
Poll
Question:
What should I do?
Part out, replace tranny and call it a day
0 (0%)
Replace with reman Auto
0 (0%)
Do a MT swap
5 (100%)
Total Voters: 5
Topic: What should I do? (Read 15757 times)
neoryan7
Re: What should I do?
September 26, 2010, 06:13:59 PM »
Quote from: timot_one on September 26, 2010, 09:35:43 AM
Is it still the aftermarket axles that you're using? I've had some pretty bad luck with aftermarket axles. Some brands are better than others of course, but OEM may be the best fit. If it were me, I'd go with a MT swap if you're going to invest the money. You've put a lot into your car to get where you are today. Sure, the MT swap will be more expensive. When you compare it to fixing your AT or replacing it with a remanufactured one, there shouldn't a ton of extra work to do with the MT swap. I think it really comes down to the cost of parts.
Yeah they gave me a new after market one i dont know if its the same company though. The first aftermarket one I recieved >100miles ago started to click after I made a u-turn. That U-turn really messed up the joint. I wasn't even giving it gas. I've made a couple of U-turns on this one and its been okay so far. Next time Im going to go with OEM or some beefier aftermarket ones, driveshaft shop maybe. Tim where did you source your 6MT from?
Quote from: CrazyCreashunz on September 26, 2010, 12:22:42 PM
Well I had same problemo in the summer... ended up spending $3700 to replace auto trans and ecu. It all depends how much longer you wanna keep your ride, which by the way looks awesome. Either replace or do a manual swap is what I would do!
I Originally planned to keep it as long as I could, I was hoping to eventually turn it to my track car as it gets older. Its my first car and have grown attached to it. Its taught me a lot about how cars work and stuff.
Quote from: Jeff on September 26, 2010, 12:35:28 PM
Just some food for thought. I too wanted to do the MT swap, so i asked Skippy for some information. He said that to do a 5AT to 5MT swap, it would be about $5000 - $6000 for parts and labor, not including shipping. He also told me that a lot of custom fabrication needs to be done, and that it's no easy task. From the looks of your car though, you should have no problem doing the swap. In my case, i would be competely clueless on what to do. It's probably not worth it for me anyways when i could take that money and put it into trading for a better car, like a v6 accord.
I got a few quotes from some reputable garages in my area and it wasn't too bad. I was quoted about 2k for MT tranny and all install. I would have to get the other components myself but that should not be more than 1200 at least I'm hoping. I also got a quote for about 1200 for used auto and labor. Honda quoted me about 4k for a reman auto with install.
September 26, 2010, 07:16:29 PM »
I got my tranny through Cham. I don't know where he sourced it from though. You may have some good luck going through car-part.com. I know Skippy got his through car-part.com. If you find anything out here on the East Coast or in New England, I'll be glad to help you out and pick it up and ship it for you. As far as the labor, I'm not sure if there's any fabrication needed because the chassis is the same, so you'd only need to bolt in the MT parts. I'm pretty sure your firewall already has the mounting holes for a clutch master cylinder. You will need to replace the brake pedal with a MT brake pedal, but that would only be like 1 bolt and 2 nuts to replace. The biggest thing will be pulling the motor to do the tranny swap or dropping the sub frame to pull the tranny.
neoryan7
October 05, 2010, 07:08:27 PM »
Thanks for the offer Tim I'll keep that in mind. LMK if you happen to come up on some good deals for MT items.
October 05, 2010, 09:56:27 PM »
I've got a bunch of broken clutch pedals and clutch master cylinders.
neoryan7
October 07, 2010, 12:43:12 AM »
how broken?
October 07, 2010, 08:10:12 AM »
Broken enough that you would want to just buy a new one from Honda. I wouldn't sell you broken parts.
neoryan7
October 07, 2010, 07:15:00 PM »
haha, do you think I can just cut the brake pedal and fit a MT pad on? Do you have a Comptech SS/Neuspeed SS or a Mugen shifter?
October 07, 2010, 07:33:09 PM »
I wouldn't. Don't be ghetto about it Ryan. I have the comptech ss and a shortened OEM shifter. You can have my OEM shifter if you want.
neoryan7
Reply #23 on:
October 07, 2010, 08:22:00 PM »
haha I wish i knew someone at Honda
Reply #24 on:
October 07, 2010, 10:35:02 PM »
Me too.
