July 25, 2026, 10:02:15 PM
one HID likes going out?
Topic: one HID likes going out? (Read 21574 times)
Re: one HID likes going out?
May 16, 2011, 08:46:22 AM »
Sounds like there is a short some where. I would look for some exposed wiring.
May 16, 2011, 09:41:25 AM »
Quote from: Mike on May 16, 2011, 08:46:22 AM
I don't think that an issue cuz it's PNP and everything looked okay... I unplugged and replugged everything nice and snug. I'm gonna get new ballast from Alex today and see if thats the issue! Gould just be a cheap HID kit I got from ebay... (crossing my fingers)
May 16, 2011, 09:50:10 AM »
I obviously don't know about your set up to much... Maybe it's a ballast PNP doesn't mean much a wire could be rubbing on something some where and worn though its protetive coating. Try unhooking the ballast you suspect and turn on your lights if the fust still blows it's not the ballast.
May 16, 2011, 10:00:17 AM »
I would do something similar to what Mike suggested. Disconnect the ballast and reconnect the stock halogen bulb. If you are still blowing fuses, then it's not the HID kit you have, it's a problem with your wiring. Usually, you blow fuses when there is too much current and the fuse blows to protect the device you're powering and to prevent your wire from burning. I'm inclined to believe there is a short somewhere, as Mike suggested. Whether it's your factory wiring, a wiring harness you may be using, or a bad ballast.
May 16, 2011, 10:18:01 AM »
Quote from: timot_one on May 16, 2011, 10:00:17 AM
I was gonna actually disconnect everything and put the stock bulb and connection back in to check. I won't be able to do so until Wednesday though so I will be in touch with the thread lolz... Thanks for the feedback Mike and Tim.
May 16, 2011, 05:20:46 PM »
Billy, you should have my number. Text me if you need help. I'll be in meetings all week, but I should be able to answer when I'm not busy. If you want, you can PM me too, but I won't be online much this week.
May 16, 2011, 06:38:10 PM »
The TTS hotline. I've used it before. (Tim's Technical Support)
May 16, 2011, 06:41:26 PM »
Quote from: timot_one on May 16, 2011, 05:20:46 PM
Had in my old phone, never got transferred over like most of my numbers! I'll PM you mine and my BBM
Quote from: gargantula99 on May 16, 2011, 06:38:10 PM
LmaoOoo....
...Hope I don't get charged per minute outside my plan
Reply #23 on:
May 16, 2011, 08:43:53 PM »
Considering that I worked for the past 5 years in technical support for home theater systems and audio products, me helping you guys over the phone is no big deal. The only difference is that I'm not getting paid, and I can tell you to fuck off and hang up if I want to.
Reply #24 on:
May 17, 2011, 02:14:32 AM »
check for over heating some hids like my 55w's come with a auto off feature when the hid ballast get too hot they shut down always mount in a cool location has happen in the past to me and i also had to swap my fuses to 30amp never happen again after that
Last Edit: May 17, 2011, 02:18:48 AM by cna
Reply #25 on:
May 18, 2011, 01:48:19 PM »
Quote from: cna on May 17, 2011, 02:14:32 AM
Not sure if it is a safe call swapping fuse for a larger amp...
Reply #26 on:
May 18, 2011, 01:52:42 PM »
Definitely not. You may fry something other than a fuse as a result.
Reply #27 on:
May 18, 2011, 02:36:37 PM »
The purpose of a fuse is to protect your wiring. If you're passing more current than a wire can handle, it will catch on fire. You may want to rethink your set up Clemente. I'd suggest using a relay harness if this is connected to your OEM headlight connectors. If you are using a relay harness already, make sure that your wire is the proper gauge for it's length to handle that amount of current.
Reply #28 on:
May 18, 2011, 06:58:35 PM »
Okay so disconnected the ballast and just hooked up the stock plug to a stock 9006 bulb and it works fine. Wiring still good, ballast not so good. Hopefully the new ones Alex's sent me come tomorrow since I'm off so I can install....
Just a thought... how come the headlights run on a 10amp fuse and the fogs on a 20amp fuse? I would think that the headlights require a larger fuse...?
My current mood: Happy as a mofo cuz it's not the wiring!
Reply #29 on:
May 18, 2011, 08:41:14 PM »
Perhaps the relays used in the fogs require more current to operate?
