September 02, 2026, 01:34:57 PM
Author Topic: Front License Plate Options  (Read 18651 times)
MTsixspeed
MTsixspeed pfffft.
« Reply #15 on: May 18, 2010, 08:06:08 PM »
Quote from: "NWINNIE34"
strut kings license plate re-locator kit, i had one and it worked great
http://www.corsportusa.com/store/catalo ... ts_id=3097
$20
$20 for that?! LOL. That gives me a couple ideas though. I'll fabricate something at work out of aluminum. Maybe I can come up with my own design and begin selling it for $19/ea!
-Chris, CM81 J30A4
mnkyman
mnkyman pfffft.
« Reply #16 on: May 18, 2010, 08:09:09 PM »
everyone who has fabbed up their own brackets, could you please post pictures?
I have an idea of what I want to do, but want to see what you all have before I go at it.
Sam -|- 2006 I4 Sedan SE
« Reply #17 on: May 18, 2010, 10:55:05 PM »
^just click on my profile page.. you can see the two L brackets kind of in the "mugshots" section.  it's literally just two "L" brackets from home depot... $5 maybe? then bolted onto the underside of that opening on the bumper.  you can put a little bit of foam tape on the bottom edge of your license plate, as it will probably hit the bottom part of the opening, so that it doesn't scratch the paint.  you can even paint the L brackets prior to installation so they aren't seen as easily. if you want more detailed pictures of the whole thing let me know, I'll try to get some for you.
mnkyman
mnkyman pfffft.
« Reply #18 on: May 19, 2010, 05:01:12 PM »
Quote from: "b_beau_09"
ahh okay, so you just have them bolted to the bumper itself?
I think i'm going to try to fab up something to mount to the stock bolt locations...basically look the same as a stock bracket, but it will be sitting in the opening gap rather than on the bumper itself
MTsixspeed
MTsixspeed pfffft.
« Reply #19 on: May 19, 2010, 09:15:32 PM »
Just don't block too much air from getting in though that opening and to your radiator.
-Chris, CM81 J30A4
Reputation Power: 11
sherker55 pfffft.
« Reply #20 on: May 19, 2010, 09:38:33 PM »
I don't get the purpose of relocation from center...it makes it look out of square
mnkyman
mnkyman pfffft.
« Reply #21 on: May 20, 2010, 02:17:34 AM »
Quote from: "sherker55"
if you are referring to my idea, i'm still going to have it center, just in that gap
Chris: Ya I was thinking about that too lol...maybe make some vent holes in the license plate...i'm sure that is perfectly legal lol
« Reply #22 on: May 20, 2010, 08:33:43 AM »
It's based on preferance. Some cars even come with them off to the side from the factory
« Reply #23 on: May 20, 2010, 12:46:59 PM »
There are 2 reasons.  The more common reason is because of how it looks.  The less common reason is because the plate is blocking the radiator or intercooler reducing air flow.
Quote from: "mnkyman"
That's not a good idea Sam.  You're basically blocking your radiator and reducing it's efficiency and effectiveness by doing that.  I'd recommend another alternative that will not affect your engine cooling.
« Reply #24 on: May 31, 2010, 10:41:16 AM »
I found this today.
http://forums.yuppieracing.net/showthread.php?t=4204
MTsixspeed
MTsixspeed pfffft.
« Reply #25 on: June 02, 2010, 05:27:29 PM »
Good one, Tim. I found this link through yours: http://gominigo.com/NHLPB-main.html
This makes me wish our cars had the tow hook point in the bumper!
-Chris, CM81 J30A4
mnkyman
mnkyman pfffft.
« Reply #26 on: June 02, 2010, 08:33:37 PM »
hmm i like this one and at only $10 at autozone, it's worth a try
MTsixspeed
MTsixspeed pfffft.
« Reply #27 on: June 05, 2010, 09:41:57 AM »
Just make sure you paint or clear coat it, Sam. Like someone posted on that site, it's made of steel and will rust if you don't take preventative measure.
-Chris, CM81 J30A4
Pages: « First 1 [2]   Go Up
