July 01, 2026, 10:58:05 AM
ECM Chatroom
97
98
99
100
1911
Topic: ECM Chatroom (Read 7495597 times)
Re: ECM Chatroom
Reply #1455 on:
June 25, 2009, 12:50:21 AM »
Quote from: "Blackhawk"
Yeah I had the same problem with my key fob screw but with some good hand pressure and the right screwdriver, you're set
OK got that screw out after all, alittle pressure worked! Well looks like it takes a Panasonic CR 1616 3V battery...
Last Edit: June 25, 2009, 01:31:00 AM by CrazyCreashunz
rocketstarter
Re: ECM Chatroom
Reply #1456 on:
June 25, 2009, 01:01:05 AM »
Quote from: "Jeff"
quick question: is there any benefit to tightening the throttle cable? How would I go about doing this if it's even worth it?
In the drivebility and precision departments yes, there's an enormous benefit if you ask me. Unless your gas pedal bopping around doesn't bother you.
1. Turn your car on and let it warm up and NOTE WHERE YOUR NEEDLE SITS, locate the throttle body and look at the top cable to the right of it. [The bottom one is for Cruise Control in case you're wandering]
2. There should be a grade8 colored plate with a tab that the cable goes through. Loosen the nut that sits on top [facing you]
3. Now the nut UNDERNEATH that plate will determine the THROTTLE POSITION. If I remember correctly turn it anti-clockwise to tighten. If you hear your RPMs rise then loosen it a tad.
4. Ultimately you don't want any play in your gas pedal. I preferred mine to react if I barely touched it with my big toe, but that's all persnal preference. YOU tghten it to how much travel YOU want it to have.
I'd take a picture to show you were it's at for a visual but my car turned into a crumpled beer can at midnight. Maybe one of the other members can take a picture of an existing engine bay and pin point the assembly to you.
Good luck!
S60R NO MO
rocketstarter
Re: ECM Chatroom
Reply #1457 on:
June 25, 2009, 01:05:34 AM »
OOPS wayyyyyy late
S60R NO MO
Re: ECM Chatroom
Reply #1458 on:
June 25, 2009, 01:18:37 AM »
lol it's ok, I appreciate the help. I think I'm going to try it again tomorrow to see if I can get it as tight as possible without raising the idle at all. I made the cruise control one kinda tight too, but that one isn't that important because I don't use cruise control. They were very loose to begin with. I had to tighten it by like a little under a 1/4 inch lol.
Before I had this nasty dead spot in the pedal. Now that's gone. I always get annoyed when I have to push down on the pedal really hard whenever I pass someone on the highway, or if I'm on the on-ramp.
Re: ECM Chatroom
Reply #1459 on:
June 25, 2009, 08:51:51 AM »
Morning everyone.
Re: ECM Chatroom
Reply #1460 on:
June 25, 2009, 09:03:08 AM »
Morning Mike….
Someone at my job is getting fired today!!! I had to leave my apartment at 2am and drive to my work site just to let a person how was locked in the building yesterday evening out. My maintenance supervisor failed to inspect the building before closing down for the day. That’s a NO NO…
I hate having to let people go but this guy should have retired a long time ago.
Last Edit: June 25, 2009, 09:03:45 AM by ibcnunv
Re: ECM Chatroom
Reply #1461 on:
June 25, 2009, 09:03:13 AM »
Morning, big Mike and the rest of ECM.
Re: ECM Chatroom
Reply #1462 on:
June 25, 2009, 09:04:51 AM »
Morning JT!!!
I see you're giving away your junk!!! LOL
Re: ECM Chatroom
Reply #1463 on:
June 25, 2009, 09:05:09 AM »
that sucks piereo, im good at yelling at people. ill do it
Re: ECM Chatroom
Reply #1464 on:
June 25, 2009, 09:09:02 AM »
yeah it is because I can’t hear very well so I tend to yell a lot!!!
Re: ECM Chatroom
Reply #1465 on:
June 25, 2009, 10:21:40 AM »
woo, dentist appointment today!
Re: ECM Chatroom
Reply #1466 on:
June 25, 2009, 11:17:32 AM »
^I had mine a few weeks ago. $60 down the drain but I guess that's good. LOL!!! I havent been to the dentist in about 10 years and I went in and she said I still have no cavities ever since the 1 I had when I was 6. She also couldnt tell that I had smoked for 10 years! So I paid $60 for her to tell me what I already knew which was everything was fine!
Re: ECM Chatroom
Reply #1467 on:
June 25, 2009, 11:26:41 AM »
dental insurance FTW
Re: ECM Chatroom
Reply #1468 on:
June 25, 2009, 12:04:09 PM »
^That's one of the only reasons I went. I finally came to the conclusion that if I'm paying for it might as well use it. I get 2 free cleanings a year that I havent been using.
Re: ECM Chatroom
Reply #1469 on:
June 25, 2009, 12:10:29 PM »
i gotta get a root canal done in two weeks... apparently my last dentist missed a deepening hole in one of my teeth over a period of 4 years(looked at x rays and just examined my teeth but the bitch managed to miss it) and my new dentist found it today.......... what the fuck
97
98
99
100
1911
