August 05, 2026, 07:04:18 PM
Fuel Economy Thread
Topic: Fuel Economy Thread (Read 148831 times)
Re: Fuel Economy Thread
May 08, 2010, 01:47:23 AM »
You can do resistance test on your O2 sensors to check for proper operation.
Can you further elaborate on this procedure?
neoryan7
May 09, 2010, 02:02:21 AM »
O2 sensors don't necessarily fail completely and at once. They can lose their efficiency/speed slowly that the ecu might not be able to detect it.
May 09, 2010, 09:23:51 AM »
im not sure how many mileage you have on the car, but some poeple on here changed them at 100km. i have 103km and i changed them yesterday, and there was a noticeably improvement in performance. ill let you know if i notice an improvement in fuel economy. if you have over 100km it wouldn't hurt to change them
May 09, 2010, 10:25:20 AM »
What about weight? Do you have anything heavy in your car or are you carrying around something new? Did you get different wheels or tires? I agree with Mike though. Get an alignment done because that can definitely make a difference.
May 09, 2010, 12:11:00 PM »
Quote from: "clapton924"
Just pick up a Haynes manual at your local parts store it should be in there.
stirfriedferret
May 10, 2010, 01:22:57 PM »
Quote from: "fabulous010"
Keep me posted with that. I'm at 103k miles so that may be a necessity. I know my tech recommended the same thing for my mom's mdx.
I have nothing in my car. Literally. Only me and a backpack. I still have my work emotions, not much different from my old 5zigens. I used to get good gas mileage with the same setup back then.
Althoughhhhhh something may have come up. Before, my car used to make this weird noise from the front left wheel hub. It's not a grinding or a clicking noise, but a sort of metal on metal clicking sound. It's constant. Doesn't matter whether or not I'm turning. As long as the wheel is turning, it makes the noise. I also have another noise, which may be associated with this. When I'm driving at highway speeds and I'm making a sweeping right turn, the front left tire hums... But only when turning. It makes the same noise when I'm turning left, but not as much. It's the signs of a bad wheel bearing and I know it's not good to keep driving with it. Any ideas on whether or not that can cause poor fuel economy? Also, has anyone had a wheel bearing go bad on them?
Brian
SoCalCM Squad
EliteCM Profile
May 10, 2010, 10:00:32 PM »
to check if your wheel hub, simply lift your car and check for play in the wheel. your wheel shouldnt have any play when you try to move it up and down. also if you have a nail in your tire it could cause your tire to click. check to see if you have anything in your tire
May 10, 2010, 10:53:50 PM »
A bad wheel bearing could be the culprit also Brian. I had to replace a rear wheel bearing a few years ago when I lost it on an icy road and went into a small snow bank sideways. You should be able to pull it off man. It's not impossible to do.
stirfriedferret
Reply #23 on:
May 10, 2010, 10:58:34 PM »
There's no play in the wheel. Just noise. But the wheel bearing is bad. I know it.
Yeah, I figured it could be an issue too. I'm just thinking that a front wheel bearing could be more difficult to do than a rear wheel bearing.
Brian
SoCalCM Squad
EliteCM Profile
Reply #24 on:
May 10, 2010, 11:22:02 PM »
Are the wheels and the same size and weight as the old ones?
stirfriedferret
Reply #25 on:
May 11, 2010, 12:23:59 AM »
They'ye maybe 1lb heavier. Definitely lighter than oe.
Brian
SoCalCM Squad
EliteCM Profile
Reply #26 on:
May 11, 2010, 08:02:44 AM »
Tires also?
stirfriedferret
Reply #27 on:
May 11, 2010, 11:47:12 AM »
Same size as my first set of aftermarket wheels when I used to get good gas mileage.
Brian
SoCalCM Squad
EliteCM Profile
Reply #28 on:
May 11, 2010, 02:48:40 PM »
I'm being nit picky about the weight. Certain wheels and tires may be the exact same size, but a completely different weight. Have you done an alignment yet?
stirfriedferret
Reply #29 on:
May 11, 2010, 08:59:58 PM »
I have not... I'm going to get that done first thing tomorrow. I'll probably find the spec sheet to be super ridiculous.
Brian
SoCalCM Squad
EliteCM Profile
