June 16, 2026, 09:50:30 AM
Not shifting into 5th
Topic: Not shifting into 5th (Read 24500 times)
neoryan7
Re: Not shifting into 5th
Reply #45 on:
January 12, 2010, 04:04:22 AM »
I dont know if i have a code but sounds like my car.
DTC - P0715 (INPUT SHAFT SPEED SENSOR SYSTEM)
Code No. P0715 input shaft speed sensor system
If no output pulse is detected from the input shaft speed sensor for 1 second or more while driving in 3rd or 4th gear at a speed of 30 km/h (19 mph) or more, it is judged to be an open circuit or short-circuit in the input shaft speed sensor and diagnostic trouble code No. P0715 is output. If diagnostic trouble code P0715 is output four times, the transaxle is locked into 3rd gear or 2nd gear as a fail-safe measure.
Probable cause
Malfunction of the input shaft speed sensor
Malfunction of the underdrive clutch retainer
Malfunction of connector
Malfunction of the TCM
neoryan7
Reply #46 on:
January 27, 2010, 04:49:50 PM »
Hmmmm.... Some owners of 4cyl on V6P are experiencing the same thing and they are stock. Maybe its the ATF strainer?
Reply #47 on:
January 27, 2010, 09:35:37 PM »
Hmmm. That's not a good sign.
