October 24, 2026, 06:24:39 AM
Author Topic: Excessive Cam Wear  (Read 14045 times)
« Reply #15 on: October 06, 2009, 11:18:41 PM »
That's good to know Paul. I've been known to throw my car around turns and cloverleaf on ramps (my post a few weeks back about sliding sideways on wet pavement) but my oil level has remained fairly consistent at the high mark. Any idea if the K oil pan is baffled? If not, looks like I have another project up my sleeve.
« Reply #16 on: October 07, 2009, 12:15:09 AM »
My next motor will have a Type S oil pump in it, so hopefully that will help alleviate that issue.
« Reply #17 on: October 07, 2009, 08:21:40 AM »
Are you going to have a modded types s pump? I've read that it has cavitation issues at high rpm. People either mod it to fix the issue or mod an s2k pump slightly to bolt up.
« Reply #18 on: October 07, 2009, 08:30:42 AM »
The ERL S2000 oil pump is about $500, so I'm not sure if I can afford it with this build.  The Type S oil pump should be fine at the redline I am planning.  I'm not planning on the redline going over 7500-8000.
« Reply #19 on: October 07, 2009, 10:10:38 AM »
I gotcha. Yeah, the type S pump would be perfectly fine at that redline. Hell, that's the way Honda designed it.
« Reply #20 on: October 07, 2009, 07:27:08 PM »
Its good up to 10k. I read about it on k20a. So unless you are rev pass 10k your good to go bro.
« Reply #21 on: October 08, 2009, 12:57:01 AM »
I've been doing more research, and considering the redline I will have, I'm not going to really need to pull the bottom of the motor off just to swap oil pumps.  I'd rather not pull the motor apart and have a potential for problems down the road.  The K24A2 oil pump should be fine up to an 8k redline.  The Type S oil pump should only be good up to a 9k redline, the ERL modified S2000 oil pump is good up to a 10k redline.
Pages: « First 1 [2]   Go Up
