November 09, 2026, 07:15:21 PM
Wheels & Tires
Wheel Offset and Tire Size Calculator
Topic: Wheel Offset and Tire Size Calculator (Read 63285 times)
Re: Wheel Offset and Tire Size Calculator
Reply #30 on:
February 25, 2010, 12:06:24 AM »
If you have the opportunity, run 235's. If you want to be a baller like me, run 245's.
Well I would have to see your tires up close again to see if I would run 245. Im running 225 now so 235 would def be off the skinny side... I have plenty of time before I get some rubber. Thanks for the input Tim
Reply #31 on:
March 01, 2010, 01:57:11 PM »
not having much luck with the calcultor so i will ask anyways, im looking at a set of 17x7 and need to know what tire size would be best. any suggestions?
Reply #32 on:
March 01, 2010, 02:26:38 PM »
The calculator works fine for me. Strange?!?!
Considering you're looking for something close to the 205/60/16 that your car came with, and you are getting such skinny wheels, I'd suggest 215/50/17's or 225/50/17's. What wheels are they anyway?
Reply #33 on:
March 01, 2010, 02:42:54 PM »
im lookin at a few different and havent narrowed it down to one yet, and as far as the tire size i was thinking that a 225/45 would keep me closest to the oem rolling diameter
Reply #34 on:
March 01, 2010, 07:32:00 PM »
225/50 should be closer
Reply #35 on:
March 02, 2010, 07:19:38 AM »
k, thanks.
MuGEN7Accord
BANNED
Reply #36 on:
June 27, 2010, 12:02:56 PM »
I want to order these rims but i dont know if they will fit my rear
they are 17X9 35 offset and i am slammed all around.
my fenders are not rolled yet.
Tires i want streetched tires!!
Reply #37 on:
June 27, 2010, 12:47:58 PM »
Sure man. Go for it.
Reply #38 on:
June 27, 2010, 09:40:46 PM »
Quote from: "MuGEN7Accord"
Stretched tires are unsafe man! Don't fall into this trend.
Reply #39 on:
June 27, 2010, 09:49:08 PM »
that depends how much you stretch. a slight stretch, given that the tire width still falls within the acceptable range for the width of the wheel, can heed better performance. i.e. a 255 on a 9.5" wheel.
now if you're planning to stretch a 205 on a 9", then that's just stupid and unsafe.
as for the 17x9 +35 fitment, you'll need to roll fenders and run some negative camber. depending on your tire size, will decide how much camber you need to run and how much you need to roll you fenders.
Reply #40 on:
June 27, 2010, 09:56:47 PM »
They'll be hellaflush approved.
Reply #41 on:
June 27, 2010, 10:14:33 PM »
actually, they probably won't be.. they'll sit flush, but they won't be hellaflush..
and if he stays with his current ride height (the ride height he has in the pictures on his profile), he won't be low enough to be considered hellaflush..
Reply #42 on:
June 27, 2010, 10:15:52 PM »
Those hellaflush guys are dicks.
Reply #43 on:
December 22, 2011, 08:26:09 PM »
I'll probably never fully understand when it comes to these things lolz...
Will this work on my ride... I know the normal offset should be +38^ but how will the below affect me on a daily basis?
Size: 2 Front Rims are 18X8.75 with +20 offset
Size: 2 Rear Rims are 18x9.75 with +20 offset
Reply #44 on:
December 22, 2011, 08:51:39 PM »
I've never been a fan of wider wheels on the rear of a fwd car. Just my $.02.
I told the same thing to Pete. I miss that dude.
