September 30, 2026, 07:19:02 PM
Pages: « First < Previous 1 2 3 [4]   Go Down
Author Topic: Asimo's Audio Build (short circuit ??? )  (Read 26988 times)
Asim pfffft.
« Reply #45 on: September 29, 2009, 07:27:41 PM »
Could it be possible that I am clipping the amp?
The gain was set to maximum always with the deck sub level at 9/15 for the most part
I did try it with gain much lower and deck sub level 15/15 and it didn't change the noise.
I am buying that relay from crutchfield now since my local stores close by the time im finished work
« Reply #46 on: September 29, 2009, 09:25:59 PM »
No, that is not the symptoms of clipping your amp.  For the record, the input gain is not a volume knob.  You need to match the gain (input sensitivity) to the output of your amplifier, otherwise it will clip.  If it's not loud enough, get a more powerful amplifier, better speakers, and a properly designed enclosure.
Pages: « First < Previous 1 2 3 [4]   Go Up
