October 30, 2026, 12:28:41 PM
diff kind of rims...
Topic: diff kind of rims... (Read 18903 times)
toinkee69
Re: diff kind of rims...
July 15, 2009, 05:16:12 PM »
they are RAYS foundary rims. duno exactly what type tho. made in japan, JDM yo! hella light to, hehehehehe...i'll take better pics later. spacers are really needed to pull this one out, wish it was wider to. still have my mesh rims w/ tires tho. might just run these for a while then switch back to mesh when i'm tired of 'em. appreciate all the +/- comments guys.
-jowell
SOCalCM squad leader
July 15, 2009, 05:27:45 PM »
Rock them for a while because when you go back to the mesh wheels you'll feel like it's a new ride again.
July 15, 2009, 07:12:03 PM »
looks funny. kinda reminds me of lambo wheels
July 15, 2009, 07:51:55 PM »
Are those the old school Rays Engineering Versus?
toinkee69
July 15, 2009, 10:20:30 PM »
yep, that's what they are.
http://www.upgrademotoring.com/wheels/turismodolce.htm
-jowell
July 15, 2009, 10:43:43 PM »
Woo hoo. Score 1 for me.
July 15, 2009, 10:58:38 PM »
Quote from: "MyNameIsThien"
Great eye!!! You truely know your wheels and tires!
July 15, 2009, 11:09:03 PM »
Haha thanks, If you need spacers, it must have a really low offset. Any clue on the offset?
Reply #23 on:
July 15, 2009, 11:15:36 PM »
Maybe they'll look better powder coated or painted.
toinkee69
Reply #24 on:
July 15, 2009, 11:45:15 PM »
+50 on the offset. i'm thinking 5mm or should i go 10mm? if i use 5mm do i need to have my bolts changed still? and 5mm would just bring me to my previous wheel specs.
-jowell
Reply #25 on:
July 16, 2009, 12:22:33 AM »
5mm should be fine. You won't need to change your studs for a 5mm. When you step up to a 10 and 15mm, I suggest getting the spacer extension kit. Where the spacer has the studs built into it, and it bolts up to your previous studs.
toinkee69
Reply #26 on:
July 16, 2009, 12:49:50 AM »
^^^ big relief to know that thien, thanks for the info.
-jowell
Reply #27 on:
July 16, 2009, 01:06:00 AM »
No problem at all Jowell. I suggest either the Project Kics or Ichiba spacers. I lean more towards the Ichiba because they make a Honda/Acura application where it has the hub bore with the exact size of the applications.
Here is the Ichiba one for the TSX which of course will work for the Accords.
http://www.optionimports.com/icwhspveiiac24.html
Project Kics
http://www.evasivemotorsports.com/merch ... eel_Spacer
Ichiba one is a lot cheaper compared to the Project Kics. With both of these spacer extension kit, your wheels will need an open slot so the stock studs can clear.
toinkee69
Reply #28 on:
July 16, 2009, 03:45:30 PM »
ty thien, that's good to know.
-jowell
Reply #29 on:
July 16, 2009, 04:17:50 PM »
No problem at all. Just be aware of some spacers that don't have a hub bore. If there is no hub bore on the spacer, then all the weight of the car and wheels rest on the studs. Which in terms can cause a lot of stress on the studs themselves to even possibily snap and break.
