September 26, 2026, 07:29:53 PM
Wheels & Tires
Would these Infiniti G37S rims fit our ride?
Topic: Would these Infiniti G37S rims fit our ride? (Read 19777 times)
Re: Would these Infiniti G37S rims fit our ride?
July 03, 2009, 09:39:43 PM »
Quote from: "Knocturnal84"
what size are those anyway
19" dude... im really feeling them especially seeing them on a SSM ride.
July 05, 2009, 08:53:59 PM »
Would these 19" Infiniti G37S rims fit our ride?
C'mon Blly. We've tried really hard to promote researching stuff first before posting topics like this. What bothers me is that you only said they were 19". Not enough information for us to answer your question. Try to do a little more research first and cross reference that with the information we posted in existing threads. You've seen my rant on the old g7a, and hopefully understand why this is kind of a sore subject for me when we already have plenty of existing "wheel and tire" threads.
July 07, 2009, 05:46:45 PM »
My bad it was a spur of the moment topic, I got happy over the rims. Next time I will do the research before asking!
phunctional
July 07, 2009, 06:26:03 PM »
http://www.hubcaphaven.com/mm5/merchant ... re_Code=HC
:shock:
CM82
ADI
July 07, 2009, 07:02:54 PM »
btw 4got to mention that the guy 4rm the pics, used front's all around.
July 07, 2009, 08:10:50 PM »
Quote from: "ADI"
Good to know...
July 07, 2009, 09:39:04 PM »
Wonder what the offset is?
July 07, 2009, 09:53:41 PM »
Front:
Wheels: 19"x8.5". Cast aluminum. Made for Nissan/Infiniti by Enkei. Weight: 26.5 lbs. Bolt pattern 114.3 x 5 Offset +43
Tires: Bridgestone Potenza RE050A 225/45/19 92W. UTQG 140AA, weight 27 lbs., tread depth 10/32"
Rear:
Wheels: 19"x9". Cast aluminum. Made for Nissan/Infiniti byEnkei. Weight: 27.5 lbs. Bolt pattern 114.3 x 5. Offset +45
Tires: Bridgestone Potenza RE050A 245/40/19 94W. UTQG 140AA, weight 30 lbs., tread depth 10/32"
Other: Lugs- 60° tapered seat, 2.7oz/76 grams each. OEM wheel locks- 3.2oz./91 grams each. Center caps .3oz./14 grams each. TPMS sensors (with valve stem & collar) 1.2oz/34 grams each (Part # 40700 -JK00B) .
Reply #23 on:
July 07, 2009, 09:56:45 PM »
Good luck getting those to fit a sedan properly without pulling your fenders.
Reply #24 on:
July 08, 2009, 08:49:49 AM »
Definitely. Your best bet would be to do what that other guy did and get 4 of the front rims and use them. You should probably roll your front and rear fenders either way....
Reply #25 on:
July 08, 2009, 09:30:51 AM »
Quote from: "ikethegreat"
Yea if I do get them in the future I will go all 4 fronts and do the modification of rolling the fenders, but we will see!
Reply #26 on:
July 08, 2009, 11:08:10 AM »
That's why I made that comment. Regardless of which wheels you use front or rear, you're going to have to pull your front fenders.
seththekorean
Reply #27 on:
July 20, 2009, 03:39:22 PM »
yeah +1 to what tim said.
and billy, rolling/pulling are two different things btw.
[size=150]
Seth
[/size]
04' Coupe k24a4 5AT
SECM Squad Member
Reply #28 on:
July 25, 2009, 08:42:33 PM »
Quote from: "seththekorean"
Thanks, you learn new things everyday...
