November 06, 2026, 05:18:40 PM
Author Topic: K24 Block With K20A2 head swap review and intall  (Read 98027 times)
pbplayer257
pbplayer257 pfffft.
« Reply #15 on: September 20, 2010, 12:56:43 PM »
why would i need to swap pistons? i wouldn't be changing any compression ratio or anything
« Reply #16 on: September 20, 2010, 02:21:06 PM »
Its called piston to valve contact. Same thing the old LS/VTEC's were plagued with. Read up on that link I posted.
DrunkenVIKING
DrunkenVIKING pfffft.
« Reply #17 on: June 22, 2018, 03:59:04 PM »
ok guys, has anyone actually done this build on a G7 accord? The mechanical/parts bit I’ve got figured out, but according to Hondata, they don’t make anything for our accords. I thought that was odd because I’ve read posts from other people claiming to have K-Pro. I’m just trying to figure out how to make this work. I know our ECM won’t run the K20A2 head, so do we need to just run the PRB ECM with KPro and tune it accordingly?
« Reply #18 on: June 22, 2018, 04:24:43 PM »
I have a k24a2 block with a k20a2 and I also use kpro.  I have a custom CAN converter in my ECU to use a kpro'd EP3 ecu in my Accord.  It's a custom piece that an electrical engineering friend of mine made for me to keep using the Accord gauges and other accessories like a/c.  You're better off going with ktuner instead.  It's much easier to integrate in the Accord.
DrunkenVIKING
« Reply #19 on: June 22, 2018, 11:54:31 PM »
Ok so pretty much I’m going to have to run the K20A2 ECU with custom CAN converter? Do you have part numbers and where I can get them?
« Reply #20 on: June 25, 2018, 03:19:45 PM »
That's not possible.  The CAN converter is a custom piece that you are not able to purchase.  The person that developed it for me has no interest in making more to sell.  There are only a handful of them that exist.
« Reply #21 on: June 27, 2018, 02:39:46 AM »
Buy ktuner. Plug and play
DrunkenVIKING
« Reply #22 on: July 16, 2018, 05:49:58 PM »
Yes, after talking to the guys at KTuner, thats the route i'll be going.  Just need an ECU from a 2005 and I'm in business because according to the chap i talked to, the Accord ECU is perfectly capable of running the k20a2 head. It'd just need to be tuned due to the increased air flow.  Time to get a shopping list started...
« Reply #23 on: July 17, 2018, 08:24:48 AM »
My tuner has been a big promoter of ktuner.  It seems to be a fairly solid platform.
Pages: « First 1 [2]   Go Up
