November 06, 2026, 05:18:33 PM
DIY: RDX 410cc Injector Upgrade
Topic: DIY: RDX 410cc Injector Upgrade (Read 35056 times)
Re: DIY: RDX 410cc Injectors
March 15, 2010, 02:54:20 PM »
I basically eye balled it. I know it's hard to see in the pictures where I made the cut. If you order the pig tails from Acura, you get 10, so you have 2 that you can fuck up. I remember that what I did, was slide the pig tail end into the plastic connector and use a thin Sharpie to figure out where to cut. I guess the other option would be to just buy Toyota pig tails. Those should probably fit better.
March 16, 2010, 07:08:22 AM »
i already bought the honda pigtails so i guess im gonna be using ur guestimating method.
January 11, 2011, 08:29:10 AM »
Picture links fixed and stickied the thread again.
cd5myeleanor
Re: DIY: RDX 410cc Injector Upgrade
August 01, 2015, 12:41:02 AM »
you should make this and sell it to me..ill put down a deposit ofcourse...
August 01, 2015, 07:10:55 PM »
This thread is kind of old. What exactly are you asking for?
cd5myeleanor
August 03, 2015, 04:08:46 PM »
This whole setup you've designed here. That's if you are willing...
August 03, 2015, 11:32:45 PM »
Rywire sells adapter harnesses. The RDX injectors aren't as great as people think they are. If you're looking for more fuel, I'd recommend aftermarket injectors. I use DPI injectors on my car. If you're looking to upgrade, I can get you in touch with them.
