April 21, 2026, 06:09:19 AM
Author Topic: catalyst code...  (Read 23560 times)
Paulius005 pfffft.
« Reply #15 on: July 19, 2016, 08:54:26 PM »
Just went through emissions and got `catalyst not ready`. I had the negative off my battery for about 30 minutes last week when installing my k&n short ram. Before that I was getting P0420 because of my DC header. What's strange is that I have driven more than 2 hours worth since I disconnected the battery, which should have set everything back to ready. Should I just keep the car running for 30 minutes in the garage? Or should I disconnect the negative from the battery again for 15 mins and see if it resets? I just need something to indicate to me weather or not I need to put my stock header back on to pass emissions.
Paulius San Jose, CA
Paulius005 pfffft.
« Reply #16 on: July 19, 2016, 09:07:13 PM »
Found this:
If you take your vehicle for a state
emissions test shortly after the
battery has been disconnected or
gone dead, it may not pass the test.
This is because of certain ‘‘readiness
codes’’ that must be set in the onboard
diagnostics for the emissions
systems. These codes are erased
when the battery is disconnected,
and set again only after several days
of driving under a variety of conditions.
If the testing facility determines that
the readiness codes are not set, you
will be requested to return at a later
date to complete the test. If you must
get the vehicle retested within the
next two or three days, you can
condition the vehicle for retesting by
doing the following.
Make sure the gas tank is nearly,
but not completely full (around
3/4).
Make sure the vehicle has been
parked with the engine off for 8
hours or more.
Make sure the ambient
temperature is between 20° and
95°F.
Without touching the accelerator
pedal, start the engine, and let it
idle for 20 seconds.
Keep the vehicle in Park
(automatic transmission) or
Neutral (manual transmission).
Increase the engine speed to 2,000
rpm, and hold it there until the
temperature gauge rises to at least
1/4 of the scale (about 3minutes).
Select a nearby lightly traveled
major highway where you can
maintain a speed of 50 to 60 mph
(80 to 97 km/h) for at least 20
minutes.
Drive on the highway in D (A/T)
or 5th/6th (M/T). Do not use the
cruise control. When traffic allows,
drive for 90 seconds without
moving the accelerator pedal.
(Vehicle speed may vary slightly;
this is okay.) If you cannot do this
for a continuous 90 seconds
because of traffic conditions, drive
for at least 30 seconds, then repeat
it two more times (for a total of 90
seconds).
Then drive in city/suburban
traffic for at least 10 minutes.
When traffic conditions allow, let
the vehicle coast for several
seconds without using the
accelerator pedal or the brake pedal.
If the testing facility determines the
readiness codes are still not set, see
your dealer.
« Reply #17 on: July 20, 2016, 08:26:43 PM »
Are you getting the P0420 code still? Did you disconnect the battery to erase it so you could pass your inspection?
Paulius005 pfffft.
« Reply #18 on: July 25, 2016, 02:38:28 AM »
I was able to pass inspection after doing that procedure.
I didn't disconnect the battery to pass, I was doing some electrical work so I had disconnected my battery.
Pages: « First 1 [2]   Go Up
