June 19, 2026, 01:37:51 PM
Wheels & Tires
Tire Overinflation
Topic: Tire Overinflation (Read 10652 times)
Tire Overinflation
May 03, 2009, 08:51:55 PM »
Last year I had to replace a pair of rear tires due to camber wear. I have a camber kit and I get my wheels aligned at least once a year if not every 6 months. During the year I experimented with different tire pressures....at one point going up to around 39 psi on all 4 corners. On cars with a natural negative rear camber...wouldn't upping the tire pressure decrease the amount of tire touching the road? Possibly increasing the chances of irregular tire wear?
I know our oem rear pressure spec is 30psi. At what point is a tire considered overinflated? Is it when you exceed the max psi value printed on the tire? Or is this a more complicated issue?
Thien I am looking at you
mnkyman
Re: Tire Overinflation
May 03, 2009, 09:52:42 PM »
depends on your definition of overinflation... I would call it max psi, but at the same time, I wouldn't suggest riding around daily with that. I think our tires are rated 32, but I usually run them around 35 all around
Sam
-|- 2006 I4 Sedan SE
May 04, 2009, 01:43:15 AM »
Everyone has a different definition of over inflation. Some tire guys will say different from others. Yes, you are correct Greg when you add more air. When you add more air, you are stiffening the tires. Stiffening the tires will make the ride more harsh, and it will make the tire's contact point to the road decrease. Certain tires are made soft or hard to make gripping better. On certain tires and cars, over inflating passed 10psi over what the vehicles place card can cause tire wear. Since our vehicles call for (on cars equipped with a 195/65 R15 or 205/65 R15 will call for 30psi, 205/60 R16 or 215/50 R17 call for 32psi in the front and 30psi in the rear) roughly around 30-32 psi, I suggest not excedding passed 40psi. I would keep it around 32-35psi for daily driving. I myself keep my tires at 35psi.
mnkyman
May 04, 2009, 02:50:34 AM »
forgot to add, the only time I went over 35 was when I was autoxing and I put it at max (i think its 50)...I had some mad tire wear around the edges on the outside, but not on the inside...i'm thinking that had more to do with the tire rolling when I ran at a lower psi
Sam
May 04, 2009, 04:59:36 PM »
You guys are talking about stock wheel and tires. What about aftermarket, especially when we've increased rim and tire size? Obviously you cant go by what the manual or sticker on the car says because they're talking about a 16" wheel and tire.
May 04, 2009, 05:23:57 PM »
I go by what's recommended by the tire manufacturer with aftermarket wheels. I normally stay at about 32-35 PSI for normal driving and go up to about 40 PSI for long highway trips to get better MPG.
May 04, 2009, 08:25:56 PM »
I probably havent looked hard enough, actually I know I havent but I've only seen the max psi on the sidewall of my tires. I usually keep em at 33-34 anyway though. Guess I'll give Dunlop a call if I cant find it on the tire.
May 04, 2009, 10:03:06 PM »
Thein, correct me if I am wrong...but isn't tire psi largely based on the weight of a vehicle or static load on the tire? For instance our oem front tires are 32psi and rear is 30 psi...I assume the +2psi in the front is to compensate for the weight of the engine up front.
So for instance, if you put OEM TL wheels on your accord...the OEM psi specs are tuned to the weight of a TL not an accord. I would think the oem tire psi would be best for all tires and wheels....aftermarket or not.
May 05, 2009, 10:53:39 AM »
Quote from: "clapton924"
Thien
fixed! Before Thien thrashes you. LOL!!!
May 05, 2009, 12:27:56 PM »
Quote from: "Abailey4"
May 05, 2009, 12:29:45 PM »
Thien gets pretty pissed about people fucking up his name. That's why his user name is
May 05, 2009, 12:37:53 PM »
I changed how you spelled his name and bolded it for you. Funny thing is I just looked at your original post and you spelled it right the first time. LOL!
Last Edit: May 05, 2009, 12:40:49 PM by Abailey4
May 05, 2009, 12:39:51 PM »
I before E except after C
May 05, 2009, 07:45:44 PM »
:twisted:
May 05, 2009, 09:29:12 PM »
Quote from: "MyNameIsThien"
Now, back to Greg. This is a for-warning to all. Next person who spells my name wrong will be banned.
I blame it on late night posting! lol
